Possibile implementation eim model to machine linux using python ??
If yoes what best method??
Thanks a lot…
But Every time i Need to expand my dataset i’ll ti retrain all?
Yes, consider this learning process as an iterative process.
When you have more data, once in a while retrain your model and redeploy it and you will have better results over time.
So i install in Linux edge-impulse-cli and ok but i’m not fully understand now how use model trained
Can i download model in tflite from dashboard ?
For testing in python …
Yes you can.
To use your model with python I would mostly start with one of our examples like this one:
Try to run it and then you can start changing the code.
We also have different examples for different sensors depending on your project:
- Audio - grabs data from the microphone and classifies it in realtime.
- Camera - grabs data from a webcam and classifies it in realtime.
- Camera (full frame) - grabs data from a webcam and classifies it twice (once cut from the left, once cut from the right). This is useful if you have a wide-angle lense and don’t want to miss any events.
- Still image - classifies a still image from your hard drive.
- Custom data - classifies custom sensor data.
That’s fantastic !!! Right now i have only two word on and off
how to handle???
Thanks a lot ok so i installed edge-linux-cli but when i run … for example edge-impulse-daemon
say command not found i attach installation …! how to connect at my web dashboard or download eim file??
You need the Edge Impulse for Linux CLI, see the install scripts here: https://docs.edgeimpulse.com/docs/edge-impulse-for-linux.
Seems something wrong on path … i write ```
npm config get prefix
and i have
/home/dani/.npm-global
Ok solve problem for Kali Linux !! Need to add Path manually " nano etc/enviroments and add for my case /home/dani/.npm-global/bin but now he Say can’t run in x64 machine only arm processor can i download manually eim file ?
@Daniele771 I’ve enabled the EIM models in the UI in your project (See Deployment tab). Note that on Linux x86 we don’t load hardware acceleration at the moment, so this will be pretty slow for image models, but fine for audio.
thanks a lot ! i download x86 eim…file but i have this error when i run classify.py
python3 classify.py dani.eim 1 ⨯
File “/home/dani/Immagini/linux-sdk-python-master/examples/audio/classify.py”, line 65, in
main(sys.argv[1:])
File “/home/dani/Immagini/linux-sdk-python-master/examples/audio/classify.py”, line 43, in main
model_info = runner.init()
File “/home/dani/.local/lib/python3.9/site-packages/edge_impulse_linux/audio.py”, line 132, in init
model_info = super(AudioImpulseRunner, self).init()
File “/home/dani/.local/lib/python3.9/site-packages/edge_impulse_linux/runner.py”, line 26, in init
raise Exception(‘Model file "’ + self._model_path + ‘" is not executable’)
Exception: Model file “/home/dani/Immagini/linux-sdk-python-master/examples/audio/dani.eim” is not executable
i try to run also that
edge-impulse-linux-runner --model-file /home/dani/Immagini/linux-sdk-python-master/examples/audio/dani.eim
events.js:291
throw er; // Unhandled ‘error’ event
^Error: spawn /home/dani/Immagini/linux-sdk-python-master/examples/audio/dani.eim EACCES
at Process.ChildProcess._handle.onexit (internal/child_process.js:268:19)
at onErrorNT (internal/child_process.js:470:16)
at processTicksAndRejections (internal/process/task_queues.js:84:21)
Emitted ‘error’ event on ChildProcess instance at:
at Process.ChildProcess._handle.onexit (internal/child_process.js:274:12)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
errno: ‘EACCES’,
code: ‘EACCES’,
syscall: ‘spawn /home/dani/Immagini/linux-sdk-python-master/examples/audio/dani.eim’,
path: ‘/home/dani/Immagini/linux-sdk-python-master/examples/audio/dani.eim’,
spawnargs: [ ‘/dev/shm/edge-impulse-clihPBt1n/runner.sock’ ]
can clarify why? help
It seems that you don’t have the permission to access this .eim file.
Can you try using sudo? Or grant the directory access (linux-sdk-python-master/) to your user?
You need to make the model executable via:
chmod +x path-to-model.eim
I ran chmod +x .eim and no errors. However, when ran my python program again I got the following error:
File "/home/winlinuxuser/projects/classify-vehicle/test-numpy.py", line 20, in countAxles
File "/home/winlinuxuser/.local/lib/python3.8/site-packages/edge_impulse_linux/image.py", line 19, in init
model_info = super(ImageImpulseRunner, self).init()
File "/home/winlinuxuser/.local/lib/python3.8/site-packages/edge_impulse_linux/runner.py", line 30, in init
self._runner = subprocess.Popen([self._model_path, socket_path], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
File "/usr/lib/python3.8/subprocess.py", line 858, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/usr/lib/python3.8/subprocess.py", line 1704, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
OSError: [Errno 8] Exec format error: '/home/winlinuxuser/projects/classify-vehicle/coin-detector.eim'
How are you referencing your .eim file in your python script?
From my Raspberry Pi 4 I downloaded the eim file as follows:
edge-impulse-linux-runner --download coin-detector.eim
Then I copied the .eim file to a Python program I am developing in Visual Studio Code > WSL2 > Ubuntu (my development box, where I intend to test & debug edge-impulse-linux models and OpenCV, is a Windows 10 machine with WSL2). My Python code where the model is used and crashes with the error I mentioned on my original post is the following one:
runner = None
model = 'coin-detector.eim'
dir_path = os.path.dirname(os.path.realpath(__file__))
modelfile = os.path.join(dir_path, model)
with ImageImpulseRunner(modelfile) as runner:
try:
model_info = runner.init() #<-- crashes here.
I should say, I believe to have installed edge-impulse-linux on my WSL2 > Ubuntu 20.04 development box as follows:
pip3 install edge_impulse_linux
Could the issue be the fact I am using an .eim model I downloaded from my Pi4 and I am using it on a Python program running in Ubuntu 20.04 (which should be an x86 instead)? If so, how can I download the .eim x86 file instead? If not, what I could be missing and/or doing wrong?
I too get /home/winlinuxuser/.npm-global when I run npm config get prefix in my WSL2 Ubuntu 20.04 machine. If this is a wrong path, what should the correct path be?
