Reducing the inferencing time
Hi, I trained FOMO MobileNETv2.0.1 and uploaded it to ESP-32. I used RGB 48x48 pixel images and my object detection takes approximately 1 second to get some results. I want to lower this to say 250ms to be able to get the results close to “real” time.
I have two questions:
  1. Can I run the object detection on my computer instead of ESP-32 itself? ESP-32 will just take pictures, send images through WIFI to my PC, which will then process the data a lot faster than ESP-32 itself.
  2. How can I tweak the model to make if work faster on ESP-32 itself?
  • Platform: ESP 32
  • Build Environment Details: Arduino IDE
  • OS Version: Windows 11
Hi @anurizada ,
What I think can work is using MobileNet v1 for FOMO, that will require expert mode, but I know it works.
In your project, switch to Expert mode and paste this
sys.path.append('./resources/libraries')
import os
import math, requests
from pathlib import Path
import tensorflow as tf
from tensorflow.keras.optimizers.legacy import Adam
from tensorflow.keras.applications import MobileNet
from tensorflow.keras.layers import BatchNormalization, Conv2D, Softmax, Reshape
from tensorflow.keras.models import Model
from ei_tensorflow.constrained_object_detection import models, dataset, metrics, util
from ei_tensorflow.velo import train_keras_model_with_velo
from ei_shared.pretrained_weights import get_or_download_pretrained_weights
import ei_tensorflow.training
WEIGHTS_PREFIX = os.environ.get('WEIGHTS_PREFIX', os.getcwd())
def build_model(input_shape: tuple, weights: str, alpha: float,
                num_classes: int) -> tf.keras.Model:
    """ Construct a constrained object detection model.
    Args:
        input_shape: Passed to MobileNet construction.
        weights: Weights for initialization of MobileNet where None implies
            random initialization.
        alpha: MobileNet alpha value.
        num_classes: Number of classes, i.e. final dimension size, in output.
    Returns:
        Uncompiled keras model.
    Model takes (B, H, W, C) input and
    returns (B, H//8, W//8, num_classes) logits.
    #! First create full mobile_net_V2 from (HW, HW, C) input
    #! to (HW/8, HW/8, C) output
    mobile_net_v1 = MobileNet(input_shape=input_shape,
                                weights=weights,
                                alpha=alpha,
                                include_top=True)
    #! Default batch norm is configured for huge networks, let's speed it up
    for layer in mobile_net_v1.layers:
        if type(layer) == BatchNormalization:
            layer.momentum = 0.9
    #! Cut MobileNet where it hits 1/8th input resolution; i.e. (HW/8, HW/8, C)
    cut_point = mobile_net_v1.get_layer('conv_pw_6_relu')
    #! Now attach a small additional head on the MobileNet
    model = Conv2D(filters=32, kernel_size=1, strides=1,
                activation='relu', name='head')(cut_point.output)
    logits = Conv2D(filters=num_classes, kernel_size=1, strides=1,
                    activation=None, name='logits')(model)
    return Model(inputs=mobile_net_v1.input, outputs=logits)
def train(num_classes: int, learning_rate: float, num_epochs: int,
          alpha: float, object_weight: float,
          train_dataset: tf.data.Dataset,
          validation_dataset: tf.data.Dataset,
          best_model_path: str,
          input_shape: tuple,
          batch_size: int,
          use_velo: bool = False,
          ensure_determinism: bool = False) -> tf.keras.Model:
    """ Construct and train a constrained object detection model.
    Args:
        num_classes: Number of classes in datasets. This does not include
            implied background class introduced by segmentation map dataset
            conversion.
        learning_rate: Learning rate for Adam.
        num_epochs: Number of epochs passed to model.fit
        alpha: Alpha used to construct MobileNet. Pretrained weights will be
            used if there is a matching set.
        object_weight: The weighting to give the object in the loss function
            where background has an implied weight of 1.0.
        train_dataset: Training dataset of (x, (bbox, one_hot_y))
        validation_dataset: Validation dataset of (x, (bbox, one_hot_y))
        best_model_path: location to save best model path. note: weights
            will be restored from this path based on best val_f1 score.
        input_shape: The shape of the model's input
        batch_size: Training batch size
        ensure_determinism: If true, functions that may be non-
            deterministic are disabled (e.g. autotuning prefetch). This
            should be true in test environments.
    Returns:
        Trained keras model.
    Constructs a new constrained object detection model with num_classes+1
    outputs (denoting the classes with an implied background class of 0).
    Both training and validation datasets are adapted from
    (x, (bbox, one_hot_y)) to (x, segmentation_map). Model is trained with a
    custom weighted cross entropy function.
    nonlocal callbacks
    num_classes_with_background = num_classes + 1
    width, height, input_num_channels = input_shape
    if width != height:
        raise Exception(f"Only square inputs are supported; not {input_shape}")
    WEIGHTS_PATH = './transfer-learning-weights/edgeimpulse/MobileNetV1.0_1.96x96.grayscale.bsize_96.lr_0_05.epoch_363.val_accuracy_0.14.hdf5'
    # Download the model weights
    root_url = 'https://cdn.edgeimpulse.com/'
    p = Path(WEIGHTS_PATH)
    if not p.exists():
        print(f"Pretrained weights {WEIGHTS_PATH} unavailable; downloading...")
        if not p.parent.exists():
            p.parent.mkdir(parents=True)
        weights_data = requests.get(root_url + WEIGHTS_PATH[2:]).content
        with open(WEIGHTS_PATH, 'wb') as f:
            f.write(weights_data)
        print(f"Pretrained weights {WEIGHTS_PATH} unavailable; downloading OK")
        print("")
    model = build_model(
        weights=WEIGHTS_PATH,
        alpha=alpha,
        num_classes=num_classes_with_background
    #! Derive output size from model
    model_output_shape = model.layers[-1].output.shape
    _batch, width, height, num_classes = model_output_shape
    if width != height:
        raise Exception(f"Only square outputs are supported; not {model_output_shape}")
    output_width_height = width
    #! Build weighted cross entropy loss specific to this model size
    weighted_xent = models.construct_weighted_xent_fn(model.output.shape, object_weight)
    prefetch_policy = 1 if ensure_determinism else tf.data.experimental.AUTOTUNE
    #! Transform bounding box labels into segmentation maps
    def as_segmentation(ds, shuffle):
        ds = ds.map(dataset.bbox_to_segmentation(output_width_height, num_classes_with_background))
        if not ensure_determinism and shuffle:
            ds = ds.shuffle(buffer_size=batch_size*4)
        ds = ds.batch(batch_size, drop_remainder=False).prefetch(prefetch_policy)
        return ds
    train_segmentation_dataset = as_segmentation(train_dataset, True)
    validation_segmentation_dataset = as_segmentation(validation_dataset, False)
    validation_dataset_for_callback = (validation_dataset
        .prefetch(prefetch_policy))
    #! Initialise bias of final classifier based on training data prior.
    util.set_classifier_biases_from_dataset(
        model, train_segmentation_dataset)
    if not use_velo:
        model.compile(loss=weighted_xent,
                    optimizer=Adam(learning_rate=learning_rate))
    #! Create callback that will do centroid scoring on end of epoch against
    #! validation data. Include a callback to show % progress in slow cases.
    callbacks = callbacks if callbacks else []
    callbacks.append(metrics.CentroidScoring(validation_dataset_for_callback,
    callbacks.append(metrics.PrintPercentageTrained(num_epochs))
    #! Include a callback for model checkpointing based on the best validation f1.
    callbacks.append(
        tf.keras.callbacks.ModelCheckpoint(best_model_path,
            monitor='val_f1', save_best_only=True, mode='max',
            save_weights_only=True, verbose=0))
    if use_velo:
        from tensorflow.python.framework.errors_impl import ResourceExhaustedError
        try:
            train_keras_model_with_velo(
                model,
                train_segmentation_dataset,
                validation_segmentation_dataset,
                loss_fn=weighted_xent,
                num_epochs=num_epochs,
                callbacks=callbacks
        except ResourceExhaustedError as e:
            print(str(e))
            raise Exception(
                "ResourceExhaustedError caught during train_keras_model_with_velo."
                " Though VeLO encourages a large batch size, the current"
                f" size of {batch_size} may be too large. Please try a lower"
                " value. For further assistance please contact support"
                " at https://forum.edgeimpulse.com/")
    else:
        model.fit(train_segmentation_dataset,
                validation_data=validation_segmentation_dataset,
                epochs=num_epochs, callbacks=callbacks, verbose=0)
    #! Restore best weights.
    model.load_weights(best_model_path)
    #! Add explicit softmax layer before export.
    softmax_layer = Softmax()(model.layers[-1].output)
    model = Model(model.input, softmax_layer)
    return model
EPOCHS = args.epochs or 60
LEARNING_RATE = args.learning_rate or 0.001
BATCH_SIZE = args.batch_size or 32
model = train(num_classes=classes,
              learning_rate=LEARNING_RATE,
              num_epochs=EPOCHS,
              alpha=0.1,
              object_weight=100,
              train_dataset=train_dataset,
              validation_dataset=validation_dataset,
              best_model_path=BEST_MODEL_PATH,
              input_shape=MODEL_INPUT_SHAPE,
              batch_size=BATCH_SIZE,
              use_velo=False,
              ensure_determinism=ensure_determinism)
disable_per_channel_quantization = False
This is for Grayscale images though, so your DSP block should be Grayscale too. Example:
