Greetings,
I’m wondering why isn’t the EON Tuner working for my project? Only a red clock icon appears. My project ID is 90650.
Thanks!
Alex
Greetings,
Thanks!
Alex
Hello @AlexPH,
If you check the logs on the upper-right corner of the EON tuner, it says that failed: Block dsp exceeded retry limit.
I am not sure I can change some parameters on my side for the EON tuner, let me check internally with the Core Engineering team and come back to you.
I also just updated your jobs performances and time limit just in case. Could you try again and let me know?
Great thanks,
Also, if you ran it again before my previous message, the changes might have not been updated.
Hi there @louis ,
I ran it thrice and the error still persists. Will appreciate any kind of help.
Thanks,
Alex
Hello @AlexPH,
I have created an internal ticket so our infra team can have a deeper look.
We will let you know when it will be solved. Thanks for your patience.
