Hello!
i am Denis and currently working with the raspberry pico 4ml (A raspberry pico with a camera module).
i trained a Model and everything is working fine! I can even classify the impuls with pasting the raw data of the classification pictures. But it seems to not work with the camera input and i dont understand why.
I think its related to this problem and i even use the code from this example.
The detection percentage is always <50 and most of the time even < 1 percent and i cant understand why.
With the raw data of a classification i get a clean ´53% detection and everything is working as predicted.
Any thoughts ? Would love to understand the problem.
i guess its a problem with converting the camera data ?
Kind Regards
Denis
My main (followed the instructions from the posts etc.)
#include <hardware/gpio.h>
#include <hardware/uart.h>
#include <pico/stdio_usb.h>
#include <stdio.h>
#include <LCD_st7735.h>
#include "image_provider.h"
const uint LED_PIN = 25;
int PIN_CAM_SIOC = 5; // I2C0 SCL
int PIN_CAM_SIOD = 4; // I2C0 SDA
int PIN_CAM_RESETB = 2;
int PIN_CAM_XCLK = 3;
int PIN_CAM_VSYNC = 16; //GP15 hsync GP14 pixel clock
int PIN_CAM_Y2_PIO_BASE = 6; // data GPIO6*/
#define UART_ID uart0
#define BAUD_RATE 115200
#define DATA_BITS 8
#define STOP_BITS 1
#define PARITY UART_PARITY_NONE
#define UART_TX_PIN 0
#define UART_RX_PIN 1
// Globals, used for compatibility with Arduino-style sketches.
namespace {
tflite::ErrorReporter * error_reporter = nullptr;
int8_t image[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = {0};
float image_output[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = {0};
static bool debug_nn = false;
} // namespace
#ifndef DO_NOT_OUTPUT_TO_UART
// RX interrupt handler
void on_uart_rx() {
char cameraCommand = 0;
while (uart_is_readable(UART_ID)) {
cameraCommand = uart_getc(UART_ID);
// Can we send it back?
if (uart_is_writable(UART_ID)) {
uart_putc(UART_ID, cameraCommand);
void setup_uart() {
// Set up our UART with the required speed.
uint baud = uart_init(UART_ID, BAUD_RATE);
// Set the TX and RX pins by using the function select on the GPIO
// Set datasheet for more information on function select
gpio_set_function(UART_TX_PIN, GPIO_FUNC_UART);
gpio_set_function(UART_RX_PIN, GPIO_FUNC_UART);
// Set our data format
uart_set_format(UART_ID, DATA_BITS, STOP_BITS, PARITY);
// Turn off FIFO's - we want to do this character by character
uart_set_fifo_enabled(UART_ID, false);
// Set up a RX interrupt
// We need to set up the handler first
// Select correct interrupt for the UART we are using
int UART_IRQ = UART_ID == uart0 ? UART0_IRQ : UART1_IRQ;
// And set up and enable the interrupt handlers
irq_set_exclusive_handler(UART_IRQ, on_uart_rx);
irq_set_enabled(UART_IRQ, true);
// Now enable the UART to send interrupts - RX only
uart_set_irq_enables(UART_ID, true, false);
#else
void setup_uart() {}
#endif
int raw_feature_get_data(size_t offset, size_t length, float *out_ptr)
//size_t pixel_ix = offset * 2;
size_t pixel_ix = offset;
size_t bytes_left = length;
size_t out_ptr_ix = 0;
// read byte for byte
while (bytes_left != 0) {
// grab the pixel value and convert to r/g/b
uint16_t pixel = ST7735_COLOR565(image[pixel_ix], image[pixel_ix], image[pixel_ix]);
uint8_t r, g, b;
r = ((pixel >> 11) & 0x1f) << 3;
g = ((pixel >> 5) & 0x3f) << 2;
b = (pixel & 0x1f) << 3;
// then convert to out_ptr format
float pixel_f = (r << 16) + (g << 8) + b;
out_ptr[out_ptr_ix] = pixel_f;
// and go to the next pixel
out_ptr_ix++;
pixel_ix++;
bytes_left--;
// and done!
//memcpy(out_ptr, features + offset, length * sizeof(float));
return 0;
bool init_sensors() {
//stdio_uart_init();
static tflite::MicroErrorReporter micro_error_reporter;
error_reporter = µ_error_reporter;
setup_uart();
stdio_usb_init();
TfLiteStatus setup_status = ScreenInit(error_reporter);
if (setup_status != kTfLiteOk) {
TF_LITE_REPORT_ERROR(error_reporter, "Screen Set up failed\n");
ei_printf("Failed to init screen\n");
ei_printf("Sensor init successful!\n");
return true;
int main()
setup_uart();
stdio_usb_init();
gpio_init(LED_PIN);
gpio_set_dir(LED_PIN, GPIO_OUT);
if (!init_sensors()) {
while(1) {
ei_printf("Sensor init error!\n");
ei_sleep(1000);
ei_impulse_result_t result = {nullptr};
// Get image from camera.
int kNumCols = 96;
int kNumRows = 96;
int kNumChannels = 1;
while (1)
if (kTfLiteOk
!= GetImage(error_reporter, kNumCols, kNumRows, kNumChannels, image)) {
TF_LITE_REPORT_ERROR(error_reporter, "Image capture failed.");
ei_printf("Failed to get image\n");
// Run the model on this input and make sure it succeeds.
// put Edge Impulse model code here
// this is where we'll write all the output
signal_t signal;
signal.get_data = &raw_feature_get_data;
// read through the signal buffered, like the classifier lib also does
for (size_t ix = 0; ix < signal.total_length; ix += 1024) {
size_t bytes_to_read = 1024;
if (ix + bytes_to_read > signal.total_length) {
bytes_to_read = signal.total_length - ix;
int r = signal.get_data(ix, bytes_to_read, image_output + ix);
// Run the classifier
int err = run_classifier(&signal, &result, debug_nn);
if (err != EI_IMPULSE_OK) {
return 0;
// print the predictions
ei_printf("Predictions ");
// Process the inference results.
int8_t no_oak_processionary_nest = floor(result.classification[0].value * 100);
int8_t oak_processionary_nest = floor(result.classification[1].value * 100);
uint8_t header[4] = { 0x55, 0xBB, (uint8_t)oak_processionary_nest, (uint8_t)no_oak_processionary_nest };
uart_write_blocking(uart0, header, 4);
#if SCREEN
char array[10];
sprintf(array, "%d%%", oak_processionary_nest);
ST7735_FillRectangle(10, 120, ST7735_WIDTH, 60, ST7735_BLACK);
//if the poison ivy score is > 60%, change text color to red as a warning
//otherwise, text is green
if(oak_processionary_nest > 60)
ST7735_WriteString(10, 120, array, Font_16x26, ST7735_RED, ST7735_BLACK);
else
ST7735_WriteString(10, 120, array, Font_16x26, ST7735_GREEN, ST7735_BLACK);
#endif
TF_LITE_REPORT_ERROR(error_reporter, "**********");
