So, I trained the model, I have the .uf2 firmware file for RPI Pico. Is there a way I can get it to run continuous classification and trigger something when it finds the specific classificatio?
Hi @zloberto
Our firmware is available on Github and you can customize it as required: GitHub - edgeimpulse/firmware-pi-rp2040: Ingestion & inferencing firmware for the Raspberry Pi Pico (RP2040)
If you are doing images then see this file. You can take action based on the result variable. See line 162.
