Raspberry Pi Pico W Device is busy
I drag and drop the deployment uf2 file but when trying to run it trough thonny IDE i get the following error
Device is busy or does not respond. Your options:
  • wait until it completes current work;
  • use Ctrl+C to interrupt current work;
  • reset the device and try again;
  • check connection properties;
  • make sure the device has suitable MicroPython / CircuitPython / firmware;
  • make sure the device is not in bootloader mode.
Hi @zloberto ,
Welcome to the forum!
This looks like an issue with Thonny, I can see similar problems listed on their gitHub:
If you want to try following these steps, hopefully that will help. You can ask there if it doesn’t, and please keep us posted if you encounter any Edge Impulse specific errors.
