while(1) {
printf("Debug 1\n");
printf("Inferencing...\n");
for(size_t ix = 0; ix < EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE; ix += EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME) {
uint64_t next_tick = ei_read_timer_us() + (EI_CLASSIFIER_INTERVAL_MS * 1000);
buffer[ix] = get_axis(ADC_NUM);
printf("%.5f\n", buffer[ix]);
sleep_us(next_tick - ei_read_timer_us());
signal_t signal;
if(err != 0) {
printf("Error: Failed to create signal from buffer");
return 1;
err = run_classifier(&signal, &result, false);
if(err != EI_IMPULSE_OK) {
printf("Error: Failed to run classifier");
return 1;
for(size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
printf("%s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
the get_axis function
float get_axis(int adc_n) {
unsigned int axis_raw = 0;
for(int i = 0; i < NSAMP; i++) {
axis_raw = axis_raw + (adc_read());
axis_raw = axis_raw / NSAMP;
return axis_raw * ADC_CONVERT;
It always returns the same classification even tho the web model classifies correctyl. Is there a problem with my code?
