Raspberry pi 4 edge-impulse client installation error
After going through the first 4 steps, the fifth step of installing edge impulse client software is failing.
The fifth command is:
npm config set user root && sudo npm install edge-impulse-linux -g --unsafe-perm
Hi @nash,
Just to confirm, are you using the Raspberry Pi OS full version (which version)? The lite OS would require installing other packages by hand.
Hi @aurel ; I am using the lite version: Would you mind listing the necessary dependencies or if you have a manual on how to connect the lite version with edge impulse?
