I setup fresh install of a Raspberry Pi 4 with a Raspberry Pi 5 MP camera.
I get this error message when running edge-impulse-linux:
Edge Impulse Linux client v1.3.8
Failed to initialize linux tool Error: Cannot find any webcams, run this command with --disable-camera to skip selection
at /usr/lib/node_modules/edge-impulse-linux/build/cli/linux/linux.js:429:23
I already searched for a bit and found the suggestion to enable Legacy support in raspi-config, but it did not help.
I get this output from v4l2-ctl:
Driver name : bm2835 mmal
Card type : mmal service 16.1
Bus info : platform:bcm2835-v4l2-0
Driver version : 5.15.32
Capabilities : 0x85200005
Video Capture
Video Overlay
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x05200005
Video Capture
Video Overlay
Read/Write
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
v4l2-ctl --list-devices
/dev/video10
/dev/video11
/dev/video12
/dev/video18
/dev/video31
/dev/media2
bcm2835-isp (platform:bcm2835-isp):
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/media0
/dev/media1
mmal service 16.1 (platform:bcm2835-v4l2-0):
/dev/video0
sudo dmesg | grep video
[ 5.046483] videodev: Linux video capture interface: v2.00
[ 5.380088] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.466266] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.081412] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.113662] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.117391] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.165105] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.165972] bcm2835-v4l2-0: V4L2 device registered as video0 - stills mode > 1280x720
[ 6.173227] bcm2835-v4l2-0: Broadcom 2835 MMAL video capture ver 0.0.2 loaded.
[ 6.189838] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.191466] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.196707] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.197665] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.205472] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.208918] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.222279] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
Any suggestions?
