I am trying to run this integration example om my Pi4.
When I run step 8: “npm run build” I get errors. This is what the log shows:
0 info it worked if it ends with ok
1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘run’, ‘build’ ]
2 info using npm@6.14.13
3 info using node@v14.17.0
4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
5 verbose run-script [ ‘prebuild’, ‘build’, ‘postbuild’ ]
6 info lifecycle edge-impulse-example-linux-with-twilio@1.0.0~prebuild: edge-impulse-example-linux-with-twilio@1.0.0
7 info lifecycle edge-impulse-example-linux-with-twilio@1.0.0~build: edge-impulse-example-linux-with-twilio@1.0.0
8 verbose lifecycle edge-impulse-example-linux-with-twilio@1.0.0~build: unsafe-perm in lifecycle true
9 verbose lifecycle edge-impulse-example-linux-with-twilio@1.0.0~build: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/node_modules/.bin:/home/pi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
10 verbose lifecycle edge-impulse-example-linux-with-twilio@1.0.0~build: CWD: /home/pi
11 silly lifecycle edge-impulse-example-linux-with-twilio@1.0.0~build: Args: [ ‘-c’, ‘tsc -p .’ ]
12 silly lifecycle edge-impulse-example-linux-with-twilio@1.0.0~build: Returned: code: 1 signal: null
13 info lifecycle edge-impulse-example-linux-with-twilio@1.0.0~build: Failed to exec build script
14 verbose stack Error: edge-impulse-example-linux-with-twilio@1.0.0 build: tsc -p .
14 verbose stack Exit status 1
14 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
14 verbose stack at EventEmitter.emit (events.js:376:20)
14 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
14 verbose stack at ChildProcess.emit (events.js:376:20)
14 verbose stack at maybeClose (internal/child_process.js:1055:16)
14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
15 verbose pkgid edge-impulse-example-linux-with-twilio@1.0.0
16 verbose cwd /home/pi
17 verbose Linux 4.19.97-v7l+
18 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “run” “build”
19 verbose node v14.17.0
20 verbose npm v6.14.13
21 error code ELIFECYCLE
22 error errno 1
23 error edge-impulse-example-linux-with-twilio@1.0.0 build: tsc -p .
23 error Exit status 1
24 error Failed at the edge-impulse-example-linux-with-twilio@1.0.0 build script.
24 error This is probably not a problem with npm. There is likely additional logging output above.
25 verbose exit [ 1, true ]
Any suggestions?
