Question About MING Blog Post?
@marcpous I loved your post on MING and EI! I’m trying to work through he example and wasn’t able to import the flow into Node-Red. Is there some trick to this I might have overlooked?
Hello @bobber first of all welcome to the Edge Impulse forums :slight_smile:
I changed the Dockerfile template from Node-RED so the flow.json may be stored in the Docker volume in order to allow you to import it as a local file through the Node-RED UI.
Let me know if that works for you :wave:
Thanks! I’ll give the update a try. :slight_smile:
