Query about integrating accelerometer and audio on an ESP32
I am working on an embedded AI project using an ESP32 board. I want to integrate motion data from an MPU6050 IMU and audio data from an INMP441 microphone into a single Edge Impulse machine learning model (sensor fusion).
Currently, I’m unsure what the best recommended method is:
  1. Record motion + audio together as one fused dataset and train one model, or
  2. Train two separate models (IMU model + audio model), then merge the deployment code and adjust metadata / axis names to avoid clashes.
I found the Edge Impulse tutorial on embeddings sensor fusion, but it does not explain how to collect/record both IMU (x,y,z) and audio together from an ESP32 in the Data Acquisition stage:
I would like guidance on the recommended approach and how to structure data collection correctly.
The goal is to develop an embedded AI classification application using both motion (MPU6050) and sound (INMP441).
Example use case: fall detection + distress voice detection.
Final model will be deployed on ESP32.
  1. Connected MPU6050 to ESP32.
  2. Connected INMP441 microphone to ESP32.
  3. Recorded audio samples using edge-impulse-daemon at 16 kHz.
  4. Recorded IMU samples using edge-impulse-data-forwarder at 20 Hz (ax, ay, az).
  5. Attempted to combine both datasets into one Edge Impulse project for sensor fusion.
I expected to be able to collect synchronized audio + IMU data for the same label (same recording session), configure an impulse that uses both signals, train a fused model, and deploy it on ESP32.
I can record accelerometer data at 20 Hz and audio data at 16 kHz, but not simultaneously as one recording.
I am unsure how to correctly acquire both IMU + audio together in Edge Impulse (i.e., one sample containing both x/y/z and audio), and whether the recommended method is:
  • One fused dataset + one model, or
  • Two separate models then merging firmware/code and modifying metadata/axis names to avoid clashes.
The embeddings sensor fusion tutorial explains combining embeddings/features but does not show how data is recorded/ingested from ESP32 with both sensors at once.
Hello @wongyankai,
Good questions!
In the tutorial that I put together, I used an Android app called Sensor Logger to collect the data simultaneously (stored in separate files), then I merged the files based on the timestamp and extrapolated the accelerometer values to match the highest frequency (the audio one). Finally I imported them in Edge Impulse using the CSV Wizard.
