I built out my classification model and the float 32 performs perfectly. However the quantized model is only at about 93.8% and is misclassifying some cases that will be very bad for the end project. Ultimately I’m going to need the results of this to be available for a python program in order to drive a robot.
I have the following devices that could run this: OpenMV H7 R2 (not plus), ras pi, laptop on Windows. I’m open to deploying to any of those, pending my ability to use the results in a python script. Any changes in model architecture, is fine with me.
I apologize if these are dumb questions, but I will need to get data from the OpenMV, classify it and then use that classification in a python script. I’m open to using any of the machines listed, changing model parameters etc.
Quantization works by reducing the precision of the model’s weights, so there will often be a bit of reduction in performance. If it performs too poorly, here are some things that can help:
Add more data. It is especially likely that performance will be lost for classes that are in a minority in the training set. If you are working with time series (such as accelerometers), try reducing the window increase, it will generate more samples.
Add some regularization (for example, some dropout layers). This helps force the network to be more resilient against the kind of error introduced by quantization. You may have to train a few more epochs to make up for the regularization.
Increase the capacity of the network. Quantization error is worse for networks that are at their capacity limit, e.g. where every parameter is super important. If you add a few more neurons or layers you might find that the issue is not as bad.
