QCS6490 Tria Vision AI Kit Edge Impulse Can't Recognise Web Cams (MIPI)
Trying to follow the Tria Vision AI Kit Deployment, get to running the Edge Impulse tool on the Vision AI Kit, but it doesn’t recognise any webcams. I have a MIPI Camera plugged into MIPI interface 1, how do I get it to recognise this / is Edge Impulse only setup to work with USB Webcams? If so is there a way I can force it to use the MIPI camera?
Running edge-impulse-linux on the QCS6490
  1. install steps follow as per guide: Tria Vision AI-KIT 6490 - Edge Impulse Documentation
  2. run edge-impulse-linux --disable-microphone
  3. System doesn’t recognise the MIPI Camera
Expect the MIPI Camera to be detected as a webcam
System reports Error: cannot find any webcams
  • [x] Always
  • Platform: TRIA Vision AI Kit QCS6490
  • **Build Environment Details: Linux qcs6490-visionai-kit 6.6.97-qli-1.6-ver-1.2-05029-g53c11c30e98d-dirty #1 SMP PREEMPT Tue Sep 16 19:00:01 UTC 2025 aarch64 GNU/Linux
  • **OS Version: QCom Robotics Reference Distro with ROS 1.6-ver-1.2
  • **Edge Impulse Version (Firmware): Edge Impulse Linux Client V1.24.2
The OS run has a demo application that uses the MIPI Camera, but Edge Impulse doesn’t recognise it. I suspect Edge Impulse is only looking for USB cameras? Is there a way I can force it to look for the MIPI Input?
Hi @edbrodbelt, thanks for the report, we’ll take a look and see what we can find out, thanks!
Please append these gstreamer launch arguments to your edge-impulse-linux command to use the MIPI cameras, with camera=0 being incremented for each of the connector ports. This will be remedied in an upcoming update, apologies for the inconvenience.
--gst-launch-args "qtiqmmfsrc name=camsrc camera=0 ! \
video/x-raw,format=NV12,width=1280,height=720,framerate=30/1,\
interlace-mode=progressive,colorimetry=bt601 ! \
videoconvert ! jpegenc"
Thanks for your help, that command now works and I can use the MIPI Camera. Much appreciated. :smiley:
Hi Edge Impulse Team.
When I run this command the camera connects to the MIPI Camera connected to CSI0 Port on the TRIA Vision AI Kit.
If I would like to run the command using CSI1 Port connected camera how would I change the command?
Changing your provided command to camera=1 instead of camera =0 throws an error, do I need to change the name=camsrc also?
Ed
My current command that throws error:
