Python sdk encounters bug when profiling for alif e7
I am trying to profile a quantized model for the Alif E7 devkit. But each time I get a validation error:
Could not profile: 1 validation error for ProfileResponse
model -> profileInfo -> int8 -> timePerInferenceMs
  value is not a valid integer (type=type_error.integer)
I don’t encounter this error when profiling the same model for other devices like the ampiq-apollo5, esp32, cortex-m4f-80mhz, cortex-m7-216mhz.
Only when profiling either the alif-he or alif-hp.
Code:
import edgeimpulse as ei
ei.API_KEY = "ei_..."
try:
    profile = ei.model.profile(
        model = "birdnet_quantized_split.tflite",
        device = "alif-hp"
    print(profile.summary())
except Exception as e:
    print(f"Could not profile: {e}")
  • OS: windows 11
  • edgeimpulse python lib version: v1.0.18
  • Python version: 3.11.7
  • target device: Alif-hp
not sure how to attach the .tflite file?
Hi @Davidvv
Welcome to the forum, ok I don’t have that kit but let me try to reproduce and check with the ML and embedded team if this is a bug or a misconfiguration.
Hi @Davidvv,
Thanks for reporting this error. The issue has been identified and fixed. In the next couple of days the solution will be in production. I will report when that is the case.
// Raul
Hi @Davidvv,
This fix has landed in production. Please give it a try and let me know.
// Raul
