Python error when building to Arduino without EON Compiler
When building for Arduino without EON I see this in the build output:
Creating job… OK (ID: 2064742)
Writing templates…
Writing templates OK
Job started
Copying Edge Impulse SDK…
Copying Edge Impulse SDK OK
Exporting TensorFlow Lite model…
Found operators [‘Add’, ‘Conv2D’, ‘DepthwiseConv2D’, ‘FullyConnected’, ‘Reshape’, ‘Softmax’, ‘Pad’]
/usr/local/lib/python3.8/dist-packages/numpy/ma/core.py:4466: SyntaxWarning: “is” with a literal. Did you mean “==”?
if self.shape is ():
Exporting TensorFlow Lite model OK
Removing clutter and updating headers…
Removing clutter and updating headers OK
Creating archive…
Creating archive OK
Job completed
Hi @andreas.bomholtz,
Does this prevent you from downloading the Arduino lib? Also, can you please send your project ID?
Thanks!
No I can still download the code, but I’m just not sure if it works correctly or not.
The Project ID is 77234
Thanks for that info! I have alerted our engineering team of the issue. Thankfully, it is just a Python3.8 warning and not an issue with the Arduino Edge Impulse SDK build, so you should be able to use your downloaded library just fine. Here’s some more information about the warning if you’re curious: https://adamj.eu/tech/2020/01/21/why-does-python-3-8-syntaxwarning-for-is-literal/
We’ll get this fixed asap.
Thanks!
