Hello, I’m trying to test the API to create a simple workflow.
The process I do is:
I sign up at Edge Impulse and get the API Key of my user.
I go to the Edge Impulse Docs and i create a JWT Token successfully with my API Key.
To test that the JWT token works good I go to Get current user API call here and I introduce my JWT token as cookie and when i run it I go an infinite loop into the docs.
Opening the Browser console I can see the error:
Access to fetch at 'https://try.readme.io/https://studio.edgeimpulse.com/v1/api/user' from origin 'https://docs.edgeimpulse.com' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: The value of the 'Access-Control-Allow-Origin' header in the response must not be the wildcard '*' when the request's credentials mode is 'include'.
I tried to use Postman to see if I could made it run. I got the JWT token successfully. Then to test the GET Current user i’m unable to introduce the JWT token as a Cookie on the Postman interface.
I tried on both my terminal with cURL and on the documentation website and it seems to work fine.
Let me know if that works on Postman too with this header.
The docs for all of the User API calls say that “This function is only available through a JWT token.” Was there another place you recommend it being listed?
From what I understand, the API keys are project-specific, so creating a request to, say, get user, with that key likely won’t work. Can you provide a screenshot of the infinite loop? I just tried that page, and I get a a regular error.
