Problems with edge-impulse-daemon on Ubuntu 22.04
Hi, I am trying to connect my Arduino 33 BLE board to EdgeImpulse.
I have been following the guide here:
I installed Edge Impulse CLI.
Then I installed Arduino CLI.
Then I installed GNU Screen.
I connected the board to my Ubuntu 22.04 laptop with a known working USB cable (uploaded Arduino sketches successfully) and put the Arduino into bootloader mode.
I downloaded the latest firmware and successfully flashed it to the Nano 33 BLE.
But when I run the command:
edge-impulse-daemon
I get the error:
edge-impulse-daemon: command not found
I have tried uninstalling and reinstalling the edge-impulse-cli with no change.
I’m not sure what to try next.
Any help is greatly appreciated!
Hi @Rossco_S
Can you try the following, and post the output?
  1. npm uninstall edge-impulse-cli -g
  2. npm install edge-impulse-cli@latest -g
Hi @Eoin
removed 372 packages in 1s
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https :// github.com/ request/ request/issues/3142
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https ://github .com/ visionmedia/debug/issues/797)
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https ://github.com/ visionmedia/debug/issues/797)
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https:// github. com/ visionmedia/debug/issues/797)
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.0: request has been deprecated, see https:// github. com/request/ request/issues/3142
added 372 packages in 23s
(It wouldnt let me post multiple links so I added spaces in them)
13 packages are looking for funding
run npm fund for details
I then tried running:
edge-impulse-daemon
Make sure edge-impulse-daemon is in your $PATH.
