Problems using WebAssembly in Node Red / Python3
**Question/Issue: I’m trying to use node-red-contrib-edge-impulse (node) together with a WebAssembly built to classify an audio signal. - However the classification results in node red are not the same compared to “Live Classification” on the Edge Impulse Website (e.g. class x=0.9 vs x=0.1) . When I try to run the same WebAssembly (Browser) on a RPI with Python3 I have the same problem. I’ve tried this with different projects. It almost seems the Web Assembly I download from the website is not the same used in Live Classification / Launch in Browser…- Any help would be greatly appreciated! Even if someone could just confirm they have used this function recently and it’s working. Then I can keep troubleshooting… Thanks a lot Jens
