I am getting this response when I deployed my model on ESP32 dev module kit with an accelerometer connected to the board… Should I only use a board with in-built inertial sensor to deploy it? or is there any possibility that I can run it directly though ESP32…
I am not sure the ready-to-use firmware works with Gyr and Mag enabled. It is possible that only accelerometer works using the LIS3DHTR module connected to I2C (SCL pin 22, SDA pin 21).
Can you make sure you have the right sensor, attached to the right pin?
No, this accelerometer is not supported.
For unsupported sensors, you can collect the data with data forwarder and then use Arduino library for inference.
I first tried uploading the source code in Arduino nano 33 BLE Sense and got the output but when I tried to upload the same code in ESP32 it showed compilation error
Yes, of course you would get a compilation error - because the code is for Arduino nano 33 BLE Sense and not for ESP32. You will need to modify it to use the ADXL345 acceleromter.
I went through the code again but I am not able to find out exactly where to make changes… Could you please suggest what possible changes can be made on the code
I am attaching the code here:
Copyright (c) 2021 EdgeImpulse Inc.
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the “Software”), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
/* Includes ---------------------------------------------------------------- */ #include <Inertial_second_review_inferencing.h>
@brief Arduino main function
void loop()
ei_printf(“Edge Impulse standalone inferencing (Arduino)\n”);
if (sizeof(features) / sizeof(float) != EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
ei_printf(“The size of your ‘features’ array is not correct. Expected %lu items, but had %lu\n”,
delay(1000);
return;
// the features are stored into flash, and we don’t want to load everything into RAM
signal_t features_signal;
// invoke the impulse
EI_IMPULSE_ERROR res = run_classifier(&features_signal, &result, false /* debug */);
ei_printf(“run_classifier returned: %d\n”, res);
