Problem with Esp32s3 in edge impluse code arduino
I need some help. I am trying to create a project that recognizes voice and responds using esp32s3, inmp441, max98357a and arduino ide. I used edge impluse to create the voice recognition and when I tested the example code it worked. But when I add the answer feedback when the voice is detected, I don’t get the answer from the speaker. Although I tried the speaker separately before, it worked fine. Here is my code:
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK   0
/* Includes */
#include <dxc3012-voice-commands_inferencing.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/i2s.h"
#include <AudioFileSourceSD.h>
#include <AudioGeneratorMP3.h>
#include <AudioOutputI2S.h>
#include "SD.h"
#include "FS.h"
#include "SPI.h"
// microSD Card Reader connections
#define SD_CS    38
#define SD_MOSI  47
#define SD_MISO  48
#define SD_SCK   21
// I2S Connections
#define I2S_DOUT       2
#define I2S_BCLK       1
#define I2S_LRC        3
// Create instances of the classes we'll use
AudioGeneratorMP3 *mp3;
AudioFileSourceSD *file;
AudioOutputI2S *out;
/** Audio buffers, pointers and selectors */
typedef struct {
    int16_t *buffer;
    uint8_t buf_ready;
    uint32_t buf_count;
    uint32_t n_samples;
} inference_t;
static inference_t inference;
static const uint32_t sample_buffer_size = 2048;
static signed short sampleBuffer[sample_buffer_size];
static bool record_status = true;
void setup()
    // Set microSD Card CS as OUTPUT and set HIGH
    pinMode(SD_CS, OUTPUT);
    digitalWrite(SD_CS, HIGH);
    // Initialize SPI bus for microSD Card
    SPI.begin(SD_SCK, SD_MISO, SD_MOSI);
    Serial.begin(115200);
    // Setup the SD card
    if (!SD.begin(SD_CS)) {
    Serial.println("Card Mount Failed");
    return;
    // Create the instances of the classes we'll use
    // file = new AudioFileSourceSD("/haha.mp3");
    out = new AudioOutputI2S();
    out->SetPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
    mp3 = new AudioGeneratorMP3();
    // Start the MP3 generator
    // mp3->begin(file, out);
    while (!Serial);
    // ei_printf("Inferencing settings:\n");
    // ei_printf("\tInterval: ");
    // ei_printf_float((float)EI_CLASSIFIER_INTERVAL_MS);
    // ei_printf(" ms.\n");
    // ei_printf("\tFrame size: %d\n", EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE);
    // ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    // ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) / sizeof(ei_classifier_inferencing_categories[0]));
    ei_sleep(2000);
    if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
        ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
        return;
    ei_printf("Recording...\n");
 * @brief      Arduino main function. Runs the inferencing loop.
void loop()
    if (!m) {
        return;
    signal_t signal;
    signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;
    signal.get_data = &microphone_audio_signal_get_data;
    EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Predictions ");
    ei_printf(": \n");
        ei_printf("    %s: ", result.classification[ix].label);
        ei_printf_float(result.classification[ix].value);
        ei_printf("\n");
    if(result.classification[0].value > 0.5) {
        if (!mp3->isRunning()) {
            // Serial.println("Playing...");
        if(mp3->isRunning()){
            if (!mp3->loop()) {
                mp3->stop();
                // Serial.println("Stopped");
    ei_printf("    anomaly score: ");
    ei_printf_float(result.anomaly);
    ei_printf("\n");
#endif
static void audio_inference_callback(uint32_t n_bytes)
    for(int i = 0; i < n_bytes>>1; i++) {
        inference.buffer[inference.buf_count++] = sampleBuffer[i];
        if(inference.buf_count >= inference.n_samples) {
          inference.buf_count = 0;
          inference.buf_ready = 1;
static void capture_samples(void* arg) {
  const int32_t i2s_bytes_to_read = (uint32_t)arg;
  size_t bytes_read = i2s_bytes_to_read;
  while (record_status) {
    /* read data at once from i2s */
    i2s_read((i2s_port_t)1, (void*)sampleBuffer, i2s_bytes_to_read, &bytes_read, 100);
    if (bytes_read <= 0) {
      ei_printf("Error in I2S read : %d", bytes_read);
    else {
        if (bytes_read < i2s_bytes_to_read) {
        ei_printf("Partial I2S read");
        // scale the data (otherwise the sound is too quiet)
        for (int x = 0; x < i2s_bytes_to_read/2; x++) {
            sampleBuffer[x] = (int16_t)(sampleBuffer[x]) * 8;
        if (record_status) {
            audio_inference_callback(i2s_bytes_to_read);
        else {
            break;
  vTaskDelete(NULL);
 * @brief      Init inferencing struct and setup/start PDM
 * @param[in]  n_samples  The n samples
 * @return     { description_of_the_return_value }
    inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
    if(inference.buffer == NULL) {
        return false;
    inference.n_samples  = n_samples;
    inference.buf_ready  = 0;
    if (i2s_init(EI_CLASSIFIER_FREQUENCY)) {
        ei_printf("Failed to start I2S!");
    ei_sleep(100);
    xTaskCreate(capture_samples, "CaptureSamples", 1024 * 32, (void*)sample_buffer_size, 10, NULL);
    return true;
 * @brief      Wait on new data
 * @return     True when finished
    bool ret = true;
    while (inference.buf_ready == 0) {
        delay(10);
    return ret;
 * Get raw audio signal data
    numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
    return 0;
 * @brief      Stop PDM and release buffers
static void microphone_inference_end(void)
    i2s_deinit();
    ei_free(inference.buffer);
static int i2s_init(uint32_t sampling_rate) {
  // Start listening for audio: MONO @ 8/16KHz
  i2s_config_t i2s_config = {
      .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_TX),
      .sample_rate = sampling_rate,
      .bits_per_sample = (i2s_bits_per_sample_t)16,
      .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
      .communication_format = I2S_COMM_FORMAT_I2S,
      .intr_alloc_flags = 0,
      .dma_buf_count = 8,
      .dma_buf_len = 512,
      .use_apll = false,
      .tx_desc_auto_clear = false,
      .fixed_mclk = -1,
  i2s_pin_config_t pin_config = {
      .bck_io_num = 42,    // IIS_SCLK
      .ws_io_num = 19,     // IIS_LCLK
      .data_out_num = -1,  // IIS_DSIN
      .data_in_num = 41,   // IIS_DOUT
  esp_err_t ret = 0;
  ret = i2s_driver_install((i2s_port_t)1, &i2s_config, 0, NULL);
  if (ret != ESP_OK) {
    ei_printf("Error in i2s_driver_install");
  ret = i2s_set_pin((i2s_port_t)1, &pin_config);
    ei_printf("Error in i2s_set_pin");
  ret = i2s_zero_dma_buffer((i2s_port_t)1);
    ei_printf("Error in initializing dma buffer with 0");
  return int(ret);
static int i2s_deinit(void) {
    i2s_driver_uninstall((i2s_port_t)1); //stop & destroy i2s driver
    return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
Hi @dxc3012
We dont really do this level of support but I can see you have not implemented any initialisation for the AudioOutputI2S speaker in the setup() function.
