I have a problem with generating features and there is this Error: Input buffer contains unsupported image format. My Images are in jpg format and are relatively small (120x60) but are not always the same size, is this the problem?
I am totally guessing here…but I conjecture that the Impulse Input Block - Image Data cannot up convert image files. So in you Impulse Design-Create Impulse try setting the
Image Width = 120and -
Image Height = 60.
IF using FOMO a square is required
Image Width = 60and -
Image Height = 60.
I’m getting this same error as well.
