Problem with EON Tuner
Trying to use EON Tuner for the last few days, and the confusion matrices are not appearing as expected - i.e. the categories all have dashes within instead of numbers. Worked really well previously with the same dataset.
Training audio classification model
Hello @LydiaK,
I just had a quick look at your project. I think the issue comes from your strongly imbalanced dataset and from the way we “round” the results.
I can see,
  • class 1 you have something like 4500 samples that last 4 seconds
  • class 2 you have 800 samples that last 1 second
  • class 3 you have 650 samples that last 1 second
So your class 1 is over represented so all your results will fall into the class 1.
I hope that helps,
Hi Louis - OK thanks for having a look. Yes I know my classes are imbalanced - I am trying to train a model for a rare event. But I will balance the training data and see if this helps. I’m just surprised as it seems to have worked previously.
I’ll see if that fixes things.
Thanks,
Lydia
Hi Louis - in deed that was the issue, thanks so much for your help!
Lydia
