Hello, this is my first question here, I am relatively new to this, when I download my Edge Impulse model to my raspberry pi, I get the following error:
Failed to run impulse Unsupported architecture “aarch64”, only armv7l or aarch64 supported for now
Can anyone tell me how I can fix this? I have tried using a 64 bit OS, but then I am getting the error message libmmal.so: No such file or directory.
I am currently using 32 bit OS Project ID:
Project ID: 247664
I am using the course provided by Edge Impulse on Coursera(Computer Vision with Embedded machine learning)
You should use the 64 bit OS to download the EIM for aarch64.
The issue about libmmal.so (after a quick search) looks related to picamera on arm64?. Can you try OpenCV instead.
I tracked this down, and there are a few things going on:
First, as @rjames mentioned, you need to use the 64-bit version of Raspberry Pi OS with Edge Impulse models.
Second, Raspberry Pi dropped support for the Picamera package going forward with Bullseye. This is what causes the “libmmal.so: No such file or directory” error message. Please use Picamera2 instead. I have updated the examples in the course’s repo to use Picamera2. You can see an example capturing live images from the Pi Camera using Picamera2 and performing inference here.
