→ I have this code of a trained model of voice recognition, downloaded from edge impulse:
/* Edge Impulse ingestion SDK
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK 0
** NOTE: If you run into TFLite arena allocation issue.
** This may be due to may dynamic memory fragmentation.
** Try defining "-DEI_CLASSIFIER_ALLOCATION_STATIC" in boards.local.txt (create
** if it doesn't exist) and copy this file to
** `<ARDUINO_CORE_INSTALL_PATH>/arduino/hardware/<mbed_core>/<core_version>/`.
** See
** (https://support.arduino.cc/hc/en-us/articles/360012076960-Where-are-the-installed-cores-located-)
** to find where Arduino installs cores on your machine.
** If the problem persists then there's not enough memory for this model and application.
#include <PDM.h>
#include <prueba_inferencing.h>
#define RED 22
#define BLUE 24
#define GREEN 23
#define BOTON 3
int val;
/** Audio buffers, pointers and selectors */
typedef struct {
int16_t *buffer;
uint8_t buf_ready;
uint32_t buf_count;
uint32_t n_samples;
} inference_t;
static inference_t inference;
static signed short sampleBuffer[2048];
void setup()
pinMode(RED, OUTPUT);
pinMode(BLUE, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BOTON, INPUT_PULLUP);
Serial.begin(115200);
while (!Serial);
ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
return;
* @brief Arduino main function. Runs the inferencing loop.
void loop()
if (digitalRead(BOTON) == LOW){
ei_printf("Starting inferencing in 2 seconds...\n");
delay(2000);
ei_printf("Recording...\n");
if (!m) {
return;
ei_printf("Recording done\n");
signal_t signal;
signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;
signal.get_data = µphone_audio_signal_get_data;
EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
if (r != EI_IMPULSE_OK) {
return;
// CODE FOR FLASHING THE NANO 33 BLE SENSE BOARD RGB LED
if (result.classification[0].value>=0.00){
digitalWrite(BLUE,LOW);
} else{
digitalWrite(BLUE,HIGH);
if (result.classification[1].value>=0.65){
digitalWrite(RED,LOW);
} else{
digitalWrite(RED,HIGH);
if (result.classification[3].value>=0.65){
digitalWrite(GREEN,LOW);
} else{
digitalWrite(GREEN,HIGH);
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
#endif
* @brief PDM buffer full callback
* Get data and call audio thread callback
static void pdm_data_ready_inference_callback(void)
int bytesAvailable = PDM.available();
// read into the sample buffer
int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable);
if (inference.buf_ready == 0) {
for(int i = 0; i < bytesRead>>1; i++) {
inference.buffer[inference.buf_count++] = sampleBuffer[i];
if(inference.buf_count >= inference.n_samples) {
inference.buf_count = 0;
inference.buf_ready = 1;
break;
* @brief Init inferencing struct and setup/start PDM
* @param[in] n_samples The n samples
* @return { description_of_the_return_value }
inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
if(inference.buffer == NULL) {
return false;
inference.n_samples = n_samples;
inference.buf_ready = 0;
// configure the data receive callback
PDM.onReceive(&pdm_data_ready_inference_callback);
PDM.setBufferSize(4096);
// initialize PDM with:
// - one channel (mono mode)
// - a 16 kHz sample rate
if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
ei_printf("Failed to start PDM!");
microphone_inference_end();
return false;
// set the gain, defaults to 20
PDM.setGain(127);
return true;
* @brief Wait on new data
* @return True when finished
while(inference.buf_ready == 0) {
delay(10);
return true;
* Get raw audio signal data
numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
return 0;
* @brief Stop PDM and release buffers
static void microphone_inference_end(void)
PDM.end();
free(inference.buffer);
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
→ I want to connect the arduino nano 33 BLE using BLE to a raspberry pi 3. I have added this to my code to get the connection:
#include <ArduinoBLE.h>
BLEService environmentService("984bce84-963e-11ed-a1eb-0242ac120002"); // Standard Environmental Sensing service
BLEIntCharacteristic ComandosCharacteristic("b3ec45b4-9586-11ed-a1eb-0242ac120002", // Standard 16-bit Temperature characteristic
BLERead | BLENotify); // Remote clients can read and get updates
void setup(){
BLE.begin();
BLE.setLocalName("Nano33BLESENSE"); // Set name for connection
BLE.setAdvertisedService(environmentService); // Advertise environment service
environmentService.addCharacteristic(ComandosCharacteristic);
BLE.addService(environmentService); // Add environment service
ComandosCharacteristic.setValue(0); // Set initial temperature value ....
→ But at the moment that I paste ble.begin() to my code, the program doesn´t work correctly, the recognition of the voice isn´t done.
→ This appears in the serial monitor:
Recording done
ERR: MFCC failed (-1002)
ERR: Failed to run DSP process (-1002)
ERR: Failed to run classifier (-5)
→ How can I solve this problem?
Thanks.
