Precise data bus error when use Edge Impulse wrapper on nRF5340
I am trying to use Edge Impulse ML models on my custom board. I have built my model on EI and downloaded it locally. I followed the sample wrapper code to use my own model but constanly get this error:[00:00:02.771,697] <err> os: ***** BUS FAULT ***** [00:00:02.771,697] <err> os: Precise data bus error [00:00:02.771,697] <err> os: BFAR Address: 0x2002065c [00:00:02.771,728] <err> os: r0/a1: 0x2001fc08 r1/a2: 0x00000149 r2/a3: 0x0000000f [00:00:02.771,759] <err> os: r3/a4: 0x00000013 r12/ip: 0x20020650 r14/lr: 0x00048553 [00:00:02.771,759] <err> os: xpsr: 0x21000200 [00:00:02.771,759] <err> os: s[ 0]: 0xaaaaaaaa s[ 1]: 0x00000149 s[ 2]: 0x00000008 s[ 3]: 0x00000002 [00:00:02.771,789] <err> os: s[ 4]: 0x2001fc08 s[ 5]: 0x2001fc08 s[ 6]: 0x00000000 s[ 7]: 0x0004859f [00:00:02.771,789] <err> os: s[ 8]: 0x00000008 s[ 9]: 0x00000008 s[10]: 0x2001fc08 s[11]: 0x000486c5 [00:00:02.771,850] <err> os: s[12]: 0x00000008 s[13]: 0x2001181c s[14]: 0x20007938 s[15]: 0x00000000 [00:00:02.771,850] <err> os: fpscr: 0x00000000 [00:00:02.771,850] <err> os: Faulting instruction address (r15/pc): 0x00048150 [00:00:02.771,881] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0 [00:00:02.771,911] <err> os: Current thread: 0x20007a08 (edge_impulse_thread) [00:00:03.226,226] <err> os: Halting system
The model can be initialised without any issue, only when I call: int err = ei_wrapper_add_data(ei_frame_data, frame_size); this specific function, the system will crash. I suspect it is a stack overflow issue.
nrf5340 SoC with edge impulse wrapper
So far, I have tried the following debug processes:
  1. Increase edge impulse stack size to 8192 and other threads’ stack size geneously
  2. Use addr2line and arm-none-eabi-objdump -d -S build/Firmware/zephyr/zephyr.elf > disassembly_3.txt to examine the specific memory address. This returns: /opt/nordic/ncs/v3.0.2/zephyr/lib/heap/heap.h:114 which points to this function: `static inline chunkid_t chunk_field(struct z_heap *h, chunkid_t c,
    enum chunk_fields f)
    chunk_unit_t *buf = chunk_buf(h);
    void *cmem = &buf[c];
    if (big_heap(h)) {
    return ((uint32_t *)cmem)[f];
    } else {
    return ((uint16_t *)cmem)[f];
  3. Depoly the same model and use the same prj.conf on nordic’s demo project
The model can be run on the nordic edge impulse wrapper official sample and with the same prj.conf.
The firmware will crash upon calling ei_wrapper_add_data(ei_frame_data, frame_size) in my own firmware code.
Always
  • Platform: [nRF5340]
  • Build Environment Details: [NCS/zephyr v3.0.2]
  • OS Version: [MacOS 15.7.1]
Complete prj.conf: `# Enable GPIO
CONFIG_GPIO=y
Enable I2C
CONFIG_I2C=y
Enable SPI
CONFIG_SPI=y
Enable log and use it via Jlink RTT rather than CDC ACM
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_RTT_CONSOLE=n
CONFIG_STDOUT_CONSOLE=n
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_UART_CONSOLE=n
CONFIG_CONSOLE=n
Enable Bluetooth LE
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME=“BORUS”
CONFIG_BT_BROADCASTER=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_FILTER_ACCEPT_LIST=y
Extended BLE
CONFIG_BT_EXT_ADV=y
CONFIG_BT_EXT_ADV_MAX_ADV_SET=2
Enale floating point unit for float point calculation
CONFIG_FPU=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_FPU_SHARING=y
Enable debugging
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_DEBUG_OPTIMIZATIONS=y
Enable multithread
CONFIG_MULTITHREADING=y
Enable battery voltage monitoring
CONFIG_SENSOR=y
CONFIG_PWM=n
CONFIG_ADC=y
CONFIG_VOLTAGE_DIVIDER=y
CONFIG_NRFX_SAADC=y
Configure USB device
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT=“BORUS”
CONFIG_USB_DEVICE_PID=0x0001
CONFIG_USB_DEVICE_VID=0x0001
CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
CONFIG_SERIAL=n
CONFIG_USB_CDC_ACM=n
CONFIG_UART_INTERRUPT_DRIVEN=n
CONFIG_UART_LINE_CTRL=n
CONFIG_BOARD_SERIAL_BACKEND_CDC_ACM=n
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
Configure USB device to appear as DFU class
Configure DFU autoupdate and reset
CONFIG_USB_DFU_CLASS=y
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_DFU_ENABLE_UPLOAD=y
CONFIG_USB_DFU_PERMANENT_DOWNLOAD=y
CONFIG_USB_DFU_REBOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y
CONFIG_BOOTLOADER_MCUBOOT=y
Configure file system
CONFIG_FLASH_MAP=y
CONFIG_FLASH=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=n
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_FS_FATFS_LFN=y
CONFIG_FS_FATFS_EXFAT=y
CONFIG_FS_LOG_LEVEL_INF=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
Configure SPI RAM buffer size
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=128
Configure mass storage
CONFIG_USB_MASS_STORAGE=y
CONFIG_DISK_ACCESS=y
CONFIG_USB_MASS_STORAGE_LOG_LEVEL_ERR=y
CONFIG_DISK_LOG_LEVEL_DBG=y
CONFIG_DISK_DRIVERS=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_DISK_DRIVER_FLASH=y
CONFIG_MASS_STORAGE_DISK_NAME=“SD”
Configure BLE encryption
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_WANT_KEY_TYPE_AES=y
CONFIG_PSA_WANT_ALG_CTR=y
CONFIG_HEAP_MEM_POOL_SIZE=262144
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
CONFIG_TEST_RANDOM_GENERATOR=y
Configure Settings subsystem
CONFIG_SETTINGS=y
CONFIG_SETTINGS_RUNTIME=y
CONFIG_NVS=y
CONFIG_SETTINGS_NVS=y
Configure Watchdog
CONFIG_WATCHDOG=y
CONFIG_WDT_DISABLE_AT_BOOT=n
Enable State Machine Framework
CONFIG_SMF=y
Enable DSP
CONFIG_CMSIS_DSP=y
CONFIG_CMSIS_DSP_FILTERING=y
CONFIG_CMSIS_DSP_TRANSFORM=y
CONFIG_CMSIS_DSP_STATISTICS=y
CONFIG_CMSIS_DSP_FASTMATH=y
CONFIG_REQUIRES_FULL_LIBC=y
CONFIG_RING_BUFFER=y
Power management
CONFIG_PM_DEVICE=y
CONFIG_RAM_POWER_DOWN_LIBRARY=y
CONFIG_POWEROFF=y
Sensor drivers and threads
CONFIG_BMI270=y
CONFIG_BMI270_TRIGGER_OWN_THREAD=y
CONFIG_BMP388=y
CONFIG_BMP388_TRIGGER_OWN_THREAD=y
CONFIG_BMP388_ODR_RUNTIME=y
CONFIG_BMP388_OSR_RUNTIME=y
Enable Edge Impulse dependencies
CONFIG_CPP=y
CONFIG_STD_CPP11=y
CONFIG_FP16=n
Enable Edge Impulse
CONFIG_EDGE_IMPULSE=y
CONFIG_EDGE_IMPULSE_URI=“/Users/gw23523/Downloads/test-cpp-mcu-v9.zip”
CONFIG_EI_WRAPPER=y
CONFIG_EI_WRAPPER_DATA_BUF_SIZE=2500
CONFIG_EI_WRAPPER_THREAD_PRIORITY=8
------------------- Turn below ON for Optimisation -------------------
Stack sizes (This needs to be optimised using the thread analyzer below)
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_ISR_STACK_SIZE=1536
CONFIG_IDLE_STACK_SIZE=512
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
CONFIG_MASS_STORAGE_STACK_SIZE=1024
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
CONFIG_EI_WRAPPER_THREAD_STACK_SIZE=4096
Thread analyser for debug purposes
CONFIG_THREAD_ANALYZER=y
CONFIG_THREAD_ANALYZER_USE_LOG=y
CONFIG_THREAD_ANALYZER_AUTO=y
CONFIG_THREAD_ANALYZER_AUTO_INTERVAL=5
CONFIG_THREAD_NAME=y
CONFIG_STACK_SENTINEL=y`
This issue is solved now by removing power_down_unused_ram()
