Hello, the board Arduino Portenta H7 (M7 core) with VisionShield can be integrated as a device in an Edge project, but you can not access the camera. Every time the error message is displayed:
[SER] Snapshot stream error: ERR: Failed to retrieve snapshot (-1).
And the board keeps going offline with the error message:
Error: Timeout when waiting for snapshot to be started or idle.
I had already uninstalled Python 3.10.4. and installed 3.9.7. but without improvement.
Thanks in advance
Could you share your project ID and which vision shield are you using?
I also suspect an issue with the board here. Could you try to use OpenMV IDE and see if you can get an image to make sure your vision shield works?
