I’m trying to get a Portenta H7 and Ethernet Vision Shield to play nice with Edge Impulse. I can’t seem to get the Edge Impulse CLI installed, so I thought I’d try connecting directly through the website to capture data. The website sees the device, but when I go to try and sample image data, Chrome crashes. It does briefly display the camera image in the browser, then boom.
FWIW, I did flash the Portenta H7 with the updated firmware. I’d love to get this working either via Chrome or via a successful CLI install.
Hi @iangillespie it would probably be best to figure out how to help you successfully install the Edge Impulse CLI as it is an essential component for the developer experience. Can you provide some more details on the problems you’re having from the CLI install.
After that, the most common error I’ve seen when installing the cli is this:
EACCES: permission denied, access ‘/usr/local/lib/node_modules’ (macOS)
This is indication that the node_modules is not owned by you, but rather by root. This is probably not what you want. To fix this, run:
I really appreciate the help. I did get Python and Node.js installed. I haven’t been seeing a permission error, I get this when I install via npm:
npm install -g edge-impulse-cli --force
npm WARN using --force Recommended protections disabled.
npm WARN deprecated @zeit/dockerignore@0.0.5: "@zeit/dockerignore" is no longer maintained
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
added 295 packages, and audited 296 packages in 13s
12 packages are looking for funding
run `npm fund` for details
**6** vulnerabilities (5 **moderate**, 1 **high**)
To address all issues (including breaking changes), run:
npm audit fix --force
Run `npm audit` for details.
iang@Ians-Air .npm-global % npm audit
npm ERR! code ENOLOCK
npm ERR! audit This command requires an existing lockfile.
npm ERR! audit Try creating one first with: npm i --package-lock-only
npm ERR! audit Original error: loadVirtual requires existing shrinkwrap file
npm ERR! /Users/iang/.npm/_logs/2021-12-11T00_44_07_885Z-debug.log
Ok, I think the problem is that your system is still pointing to python2 when it should be pointing to python3. Can you try installing like version 3.9 and see if that helps.
Ok, uninstall seemed to go fine. Then I did the install and audit:
added 295 packages, and audited 296 packages in 8s
iang@Ians-Air ~ % npm audit
found **0** vulnerabilities
But edge-impulse-daemon still says it can’t be found
iang@Ians-Air ~ % edge-impulse-daemon
zsh: command not found: edge-impulse-daemon
Ians-Air:~ iang$ npm uninstall -g edge-impulse-cli
removed 295 packages, and audited 1 package in 526ms
Ians-Air:~ iang$ npm install -g edge-impulse-cli --force
added 295 packages, and audited 296 packages in 4s
Ians-Air:~ iang$ npm audit
Ians-Air:~ iang$ npm fund
iang
Ians-Air:~ iang$ edge-impulse-daemon
-bash: edge-impulse-daemon: command not found
That’s good! Ok so now you have to add that folder to your PATH and then you should be good to go. I am not sure why the installation of node did not already do that automatically but that appears to be the issue.
