Creating job… OK (ID: 13859181)
Scheduling job in cluster…
Container image pulled!
Job started
Job started
File “/home/train.py”, line 464, in
main_function()
File “/home/train.py”, line 374, in main_function
train_dataset, validation_dataset, samples_dataset, X_train, X_test, Y_train, Y_test, has_samples, X_samples, Y_samples = ei_tensorflow.training.get_dataset_from_folder(
File “/app/./resources/libraries/ei_tensorflow/training.py”, line 237, in get_dataset_from_folder
X_train, X_test, Y_train, Y_test, X_train_raw = split_and_shuffle_data(
File “/app/./resources/libraries/ei_tensorflow/training.py”, line 55, in split_and_shuffle_data
Y = ei_tensorflow.utils.load_y_structured(dir_path, ‘y_train.npy’, len(X))
File “/app/./resources/libraries/ei_tensorflow/utils.py”, line 15, in load_y_structured
Y_structured_file = json.loads(file.read())
File “/usr/lib/python3.8/codecs.py”, line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0x93 in position 0: invalid start byte
Job failed (see above)
