Prediction using Pico is inaccurate
Why the prediction for the 3 labels is giving 0 result?
Starting inferencing in 2 seconds…
Sampling…
Predictions (DSP: 0 ms., Classification: 1 ms., Anomaly: 0 ms.):
NONE: 0.00000
OFF: 0.00000
ON: 0.00000
This is my code
#include <stdio.h>
#include "pico/stdlib.h"
#include "ei_run_classifier.h"
#include "hardware/gpio.h"
#include "hardware/adc.h"
#include "pico/cyw43_arch.h"
#define FREQUENCY_HZ 50
#define INTERVAL_MS (1000 / (FREQUENCY_HZ + 1))
#define G0 1.65f
#define NSAMP 10
char ssid[] = "";
char pass[] = "";
const float conversion_factor = 3.3f / (1 << 12);
float readAxisAccelation (int adc_n) {
adc_select_input(adc_n);
unsigned int axis_raw = 0;
for (int i=0;i<NSAMP;i++){
axis_raw = axis_raw + adc_read();
sleep_ms(1);
axis_raw = axis_raw/NSAMP;
float axis_g = (axis_raw*conversion_factor)-G0;
return axis_g;
int main()
stdio_init_all();
if (cyw43_arch_init_with_country(CYW43_COUNTRY_UK)) {
printf("failed to initialise\n");
return 1;
printf("initialised\n");
cyw43_arch_enable_sta_mode();
if (cyw43_arch_wifi_connect_timeout_ms(ssid, pass, CYW43_AUTH_WPA2_AES_PSK, 10000)) {
printf("failed to connect\n");
return 1;
printf("connected\n");
adc_init();
adc_gpio_init(28);
while (true){
ei_printf("\nStarting inferencing in 2 seconds...\n");
sleep_ms(2000);
cyw43_arch_gpio_put(CYW43_WL_GPIO_LED_PIN, 1);
ei_printf("Sampling...\n");
for (size_t ix = 0; ix < EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE; ix += EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME) {
uint64_t next_tick = ei_read_timer_us() + (EI_CLASSIFIER_INTERVAL_MS * 1000);
buffer[ix] = readAxisAccelation (2);
sleep_us(next_tick - ei_read_timer_us());
signal_t signal;
if (err != 0) {
return 1;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return 1;
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
#endif
cyw43_arch_gpio_put(CYW43_WL_GPIO_LED_PIN, 0);
//sleep_ms(INTERVAL_MS);
return 0;
This is my feature data, it should give me result “OFF”.
-6.0521, -6.2180, -6.2101, -5.2067, -6.1943, -6.2259, -5.9098, -6.2259, -6.2654, -6.2654, -6.0916, -6.2259, -6.1074, -6.2496, -6.2654, -6.2338, -6.2338, -6.2733, -6.2259, -6.2417, -6.0916, -6.2496, -6.0758, -6.1943, -6.2022, -6.2338, -6.2338, -6.2101, -6.5893, 2.7258, 5.5938, 5.5464, 4.7484, 5.5859, 5.6175, -5.0882, -6.0916, -6.2496, -5.6649, -6.2575, -6.1469, -4.4640, -2.7890, -6.6130, -6.2338, -6.2180, -6.0995, -6.2496, -6.2338, -6.2417, -6.2575, -6.2417, -6.2733, -6.2417, -7.4268, 5.6175, 5.5859, 4.6220, 5.3252, -0.2686, -6.2338, -5.5306, -6.2022, -6.1943, -6.0363, -6.2417, -6.0600, -5.5464, -6.2417, -6.2180, -4.9301, -6.2022, -6.1943, -5.8861, -6.2022, -6.2101, -6.2022, -6.0521, -6.2417, -5.6254, -6.2417, -6.2417, -6.2575, -6.2338, -6.2338, -6.2338, -6.2575, -6.2180, -6.2575, -6.2575, -6.2180, -6.2575, -6.2259, -6.2496, -6.2417, -6.2259, -5.7676, -6.2259, -6.2259, -5.3331, -6.1943, -6.2180, -6.0284, -6.2101, -6.2101, -5.3884, -6.2338, -6.1390, -5.0961, -6.2180, -6.0600, -5.9968, -6.1943, -6.2259, -6.2338, -6.2259, -6.2417, -6.1548, -6.2654, -6.2496, -6.2417, -6.1232, -6.2575, -6.2259, -6.2496, -6.1548, -6.2338, -6.2338, -6.0600, -6.2575, -6.2259, -6.2417, -6.2417, -6.2180, -5.5938, -6.2338, -6.2417, -5.2699, -6.2259, -6.2180, -5.8466, -6.2180, -6.2338, -5.9494, -6.2338, -6.2101, -5.4832, -6.2180, -6.2417, -6.2180, -6.2180, -6.1864, -6.0442, -6.2338, -6.2259, -6.1311, -6.2496, -6.2733, -6.2575, -6.2338, -6.2338, -6.2417, -6.2654, -6.2259, -6.1469, -6.2180, -6.1864, -6.2180, -6.2259, -6.2259
