I have some weird behavior with the performance calibration feature. After training my model I tried to execute the calibration but it continued to fail. After the initialization, the job throws an exception.
Here you can find the log:
Blockquote Creating job… OK (ID: 4270803)
Generating features for MFCC…
Not generating new features: features already generated and no options or files have changed.
No new features, skipping…
Generating features for MFCC OK
Running performance calibration on synthetic data…
Copying features from processing blocks…
Copying features from DSP block…
Scheduling job in cluster…
Job started
Impulse details:
Sample rate 16000 Hz
Window size 1000 ms
Learn block latency 14 ms
DSP block latency 116 ms
Total latency 130 ms
Using minimum latency 250 ms
Match tolerance 500 ms
Target test sample length is 10 minutes, including 180 test data items.
Using 32 threads for inference.
Processing 2396 windows…
Progress: 20%
Progress: 41%
Progress: 62%
Progress: 83%
DSP took 0:00:13, inference took 0:00:01
Complete
Searching for optimal post-processing configurations.
Performing maximum 50 steps or 5 minutes (1 step minimum)…
File “/home/testing.py”, line 10, in
ei_testing.testing.run_application_testing(dir_path, options)
File “/app/./resources/libraries/ei_testing/testing.py”, line 117, in run_application_testing
X, F, best_idx, problem = optimization.optimize_kws_params(
File “/app/./resources/libraries/ei_testing/optimization.py”, line 141, in optimize_kws_params
raise err
File “/app/./resources/libraries/ei_testing/optimization.py”, line 128, in optimize_kws_params
algorithm.next()
File “/app/perfcal/.venv/lib/python3.8/site-packages/pymoo/core/algorithm.py”, line 233, in next
self.evaluator.eval(self.problem, infills, algorithm=self)
File “/app/perfcal/.venv/lib/python3.8/site-packages/pymoo/core/evaluator.py”, line 95, in eval
self._eval(problem, pop[I], evaluate_values_of=evaluate_values_of, **kwargs)
File “/app/perfcal/.venv/lib/python3.8/site-packages/pymoo/core/evaluator.py”, line 112, in _eval
out = problem.evaluate(pop.get(“X”),
File “/app/perfcal/.venv/lib/python3.8/site-packages/pymoo/core/problem.py”, line 124, in evaluate
self.do(X, out, *args, **kwargs)
File “/app/perfcal/.venv/lib/python3.8/site-packages/pymoo/core/problem.py”, line 305, in do
ret = self.func_eval(self.func_elementwise_eval, self, X, out, *args, **kwargs)
File “/app/perfcal/.venv/lib/python3.8/site-packages/pymoo/core/problem.py”, line 264, in looped_eval
return [func_elementwise_eval(problem, x, dict(out), args, kwargs) for x in X]
File “/app/perfcal/.venv/lib/python3.8/site-packages/pymoo/core/problem.py”, line 257, in elementwise_eval
problem._evaluate(x, out, *args, **kwargs)
File “/app/./resources/libraries/ei_testing/optimization.py”, line 207, in _evaluate
detections = detector.process_results(self._raw_result)
File “/app/./resources/libraries/ei_testing/streaming_stats.py”, line 285, in process_results
return list(results)
File “/app/./resources/libraries/ei_testing/streaming_stats.py”, line 276, in process_result
is_new_command, label_index = self._recognizer.trigger(scores, result[‘start’])
File “/app/./resources/libraries/ei_testing/streaming_stats.py”, line 199, in trigger
raise Exception(
Exception: Scores must sum to approximately 1 but summed to 1.01171875
Job failed (see above)
Project ID: 145253
Context/Use case: Speech recognition
Thank you in advance,
Valerio
