I wanted to try the " Parameter search with Python" code found in the documentation.
I used the correct api key and can curl the impulse, but in the Python code I get the following error. How can I solve this error:
Trying filter cutoff 2.0
None
File "automate-search.py", line 145, in <module>
retrain(filter_cutoff=cutoff)
File "automate-search.py", line 87, in retrain
curr_impulse = impulse_api.get_impulse(PROJECT_ID)
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api\impulse_api.py", line 182, in get_impulse
return self.get_impulse_with_http_info(project_id, **kwargs) # noqa: E501
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api\impulse_api.py", line 251, in get_impulse_with_http_info
return self.api_client.call_api(
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api_client.py", line 337, in call_api
return self.__call_api(resource_path, method,
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api_client.py", line 181, in __call_api
return_data = self.deserialize(response_data, response_type)
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api_client.py", line 253, in deserialize
return self.__deserialize(data, response_type)
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api_client.py", line 292, in __deserialize
return self.__deserialize_model(data, klass)
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api_client.py", line 632, in __deserialize_model
kwargs[attr] = self.__deserialize(value, attr_type)
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\api_client.py", line 634, in __deserialize_model
instance = klass(**kwargs)
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\models\impulse.py", line 64, in __init__
self.window_size_ms = window_size_ms
File "C:\Users\jurg\Documents\ei\Parameter_search_with_Python\lib\site-packages\edge_impulse_sdk\models\impulse.py", line 138, in window_size_ms
raise ValueError("Invalid value for `window_size_ms`, must not be `None`") # noqa: E501
ValueError: Invalid value for `window_size_ms`, must not be `None`
