I recorded samples with ‘start’ and ‘stop’ with a sample length of 1 second. Now I have gotten this model working on an Arduino Nano 33 BLE Sense. But if I leave the settings at default in the ‘create impulse’, the model does not work. But if I set the window size to 500 ms and the window increase to 100 ms, the model works perfectly on the Arduino. What could be a reason for this?
Now I’m working on getting the same model working on a NUCLEO-L452RE-P and an SPH0645LM4H-B (I2S microphone). That hasn’t quite worked out yet. When I say the word you occasionally see the prediction go up, but for the most part noise remains the highest prediction. Could this also be due to the ‘window size’ or the buffer size that I use?
Now I saw that the SPH0645LM4H-B microphone has a negative offset, making the output largely negative. Is that a problem for the Edge Impulse model? I see that my samples signals vary around 0.
I looked at the example (ei-keyword-spotting) from ShawnHymel and used it but couldn’t figure it out.
Thanks in advance for your reply!
Johan
Project ID: 357590
