build environment:
Mac
arm-toolchain:
export GNUARMEMB_TOOLCHAIN_PATH="~/opt/gnuarmemb/gcc-arm-none-eabi-9-2019-q4-major"
nrf-sdk:
v1.6.0
Project links:
I’ve generated the cpp library and replaced:
- edge-impulse-sdk
- model-parameters
- tflite-model
The project compiles fine but when I try to run the classifier I get this “Failed to setup audio sampling” error. Any idea what the issue could be? Perhaps the sample length is too long? Thanks
AT+RUNIMPULSE
Inferencing settings:
Interval: 0.06249ms.
Frame size: 80000
Sample length: 5000 ms.
No. of classes: 4
ERR: Failed to setup audio sampling
AT+RUNIMPULSECONT
Frame size: 80000
No. of classes: 4
Starting inferencing, press 'b' to break
ERR: frame_length (0.050000) cannot be lower than frame_stride (0.140000) for continuous classification
ERR: Failed to run DSP process (-1008)
ERR: Failed to run classifier (-5)
