Try to run this but getting lots of warnings and errors.
Raha-project-1
on a Mac
Arduino CLI is installed
Python 3 is installed
Node.js 14 installed
Arduino NANO 33BLE Sense Rev2 is connected.
flash_mac.command installed
pressed RESET button once to launch the new firmware.
hello Edge Impulse community.
so I could still not install Edge Impulse CLI but could connect via the Chrome browser after I flashed your firmware again onto the board.
Hurra.
now comes the next problem though. I cannot collect data from the accelerator. The other sensors like the mic seem to work.
I checked with Arduino. Got a sketch compiled and then it worked perfectly. So it is NOT the accelerator sensor but again some stuff on your end.
Thanks in advance. This must be please resolved otherwise I am unable to continue and will have to stop this project.
Maybe I get it run with Arduino 's support all.
Do I understand correctly that the IMU is working correcty and that you can read data from the IMU? Is the goal to collect data for training and testing a model?
Hi. Yes indeed. I want to collect data (doing movements with the board) and then train a model with that data. I do not get accelerometer data though with Edge Impulse. Testing it with Arduino program it works fine all.
Currently the REV2 is not supported on Edge Impulse using the default firmware.
I invite you to use the data forwarder to collect data from the IMU: Data forwarder - Edge Impulse Documentation
