Nodejs Install Error
Question/Issue: Error when I install Node
I am trying to add a device (Arduino Nano 33BLE Sense) to my EdgeImpulse. I started with installing Python 3.11. I checked the install and was able to start it. Then I restarted my computer.
Then I installed Nodejs (18.12.1js) and checked the option to install the add-ons. When it installs the plugins, I get this error. I have tried uninstall and reinstalling a few times without any luck. Thanks in advance for your help.
python3 v3.11.0 [Approved]
python3 package files upgrade completed. Performing other installation steps.
Installing 64-bit python3…
WARNING: Generic MSI Error. This is a local environment error, not an issue with a package or the MSI itself - it could mean a pending reboot is necessary prior to install or something else (like the same version is already installed). Please see MSI log if available. If not, try again adding ‘–install-arguments="’/lv c:\python3_msi_install.log’"’. Then search the MSI Log for “Return Value 3” and look above that for the error.
ERROR: Running [“C:\ProgramData\chocolatey\lib\python3\tools\python-3.11.0-amd64.exe” /quiet InstallAllUsers=1 PrependPath=1 TargetDir=“C:\Python311” ] was not successful. Exit code was ‘1603’. Exit code indicates the following: Generic MSI Error. This is a local environment error, not an issue with a package or the MSI itself - it could mean a pending reboot is necessary prior to install or something else (like the same version is already installed). Please see MSI log if available. If not, try again adding ‘–install-arguments="’/l
v c:\python3_msi_install.log’"’. Then search the MSI Log for “Return Value 3” and look above that for the error…
The upgrade of python3 was NOT successful.
Error while running ‘C:\ProgramData\chocolatey\lib\python3\tools\chocolateyInstall.ps1’.
See log for details.
python v3.11.0 [Approved]
python package files upgrade completed. Performing other installation steps.
The upgrade of python was successful.
Software installed to ‘C:\ProgramData\chocolatey\lib\python’
Chocolatey upgraded 0/0 packages.
See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
No backup has been created before trying to reset the current configuration, and removal of the backup was not requested.
Hello @bananthan,
I can see this line:
Have you tried to proceed to the Edge Impulse CLI install? It might work.
If not can you copy the output of
npm install -g edge-impulse-cli --force
Hi Louis
I have tried that, but it does not work. Thanks for the suggestion.
One thing I notice is that after installing Nodejs, Python no longer works. I check that by running the program and it no longer takes me to the Cmd prompt.
If there are any other suggestions, please let me know.
Ravi
Would you provide more details about the error that you are getting so we can help you?
