I have created 3 spectral feature blocks each having 1,31,932 samples. But the training seems using only 18,778 samples. Below is the log:
Copying features from processing blocks...
[ 1/131932] Merging DSP blocks...
Still copying features from processing blocks...
[ 15393/131932] Merging DSP blocks...
[18778/131932] Merging DSP blocks...
Job started
Splitting data into training and validation sets...
Training model...
Training on 15022 inputs, validating on 3756 inputs
When I was using single spectral block with same number of samples it was working correctly.
Thanks for posting! I was able to take a look at your project and it appears the number of windows is now correct, at least when training NN Classifier All:
Are you still seeing the issue? Which block did your screenshot come from?
I have removed those spectral blocks which were causing issues. What you have seen is newly created blocks which are working correctly. I will recreate the problematic blocks again later today and let you know to check.
