I have gone through the process of creating of
- Creating a project
- Connecting a Nano 33 BLE Sense Board
- Acquiring data ( Training 51s and Test 51s ) :- Audio Data 16kHz
- Impulse Design
Creating an Impulse MFCC and Neural Network (Keras)
Feature Generation for MFCC
NN Classifier :- at this point I start the training and the below error occurs
Perhaps it is a data issue. Probably not enough training data for an application, but the aim was just to quickly go through the process. I tried Raw data and the MFCC which both produced this error.
Please note there is an exception within the exception, hence the first exception should be the one of most interest.
Creating job… OK (ID: 197924)
Copying features from processing blocks…
Job started
Training model
Training on 32 inputs, validating on 8 inputs
Epoch 1/100
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/data_adapter.py”, line 1136, in catch_stop_iteration
yield
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py”, line 1081, in evaluate
tmp_logs = test_function(iterator)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/def_function.py”, line 580, in call
result = self._call(*args, **kwds)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/def_function.py”, line 650, in _call
return self._concrete_stateful_fn._filtered_call(canon_args, canon_kwds) # pylint: disable=protected-access
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/function.py”, line 1665, in _filtered_call
self.captured_inputs)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/function.py”, line 1746, in _call_flat
ctx, args, cancellation_manager=cancellation_manager))
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/function.py”, line 598, in call
ctx=ctx)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/execute.py”, line 60, in quick_execute
inputs, attrs, num_outputs)
tensorflow.python.framework.errors_impl.OutOfRangeError: End of sequence
[[node IteratorGetNext (defined at home/train.py:57) ]] [Op:__inference_test_function_1022]
Function call stack:
test_function
File “/home/train.py”, line 415, in
main_function()
File “/home/train.py”, line 360, in main_function
X_train, X_test, Y_train, Y_test, len(X_train), classes)
File “/home/train.py”, line 57, in train_model
model.fit(train_dataset, epochs=100, validation_data=validation_dataset, verbose=2, callbacks=callbacks)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py”, line 66, in _method_wrapper
return method(self, *args, **kwargs)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py”, line 872, in fit
return_dict=True)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py”, line 1088, in evaluate
callbacks.on_test_batch_end(step, logs)
File “/usr/local/lib/python3.7/contextlib.py”, line 130, in exit
self.gen.throw(type, value, traceback)
File “/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/data_adapter.py”, line 1153, in catch_stop_iteration
self._inferred_steps))
TypeError: unsupported operand type(s) for *: ‘int’ and ‘NoneType’
Job failed (see above)
