Beautiful people of Edge Impulse forum,
I am trying to establish communication between Nicla Voice (keyword spotting) and Nicla Vision through I2C with ESLOV.
What I am trying to achieve: on a spotted keyword nicla voice sends a string using I2C to nicla vision.
I have already managed to do it using classic arduino sketch (keyboard commands to control nicla vision using nicla voice), but I just cannot wrap my head around integrating it into your code so I can use NN keyword spotting for the purpose of controlling the other board.
I could really appreciate some help integrating this code:
#include <Wire.h>
#include "Nicla_System.h"
const byte deviceAddress = 0x42;
String inputString = ""; // A String to hold incoming data
void setup() {
nicla::begin();
nicla::leds.begin();
Wire.begin();
Serial.begin(9600); // Start serial communication at 9600 baud to debug
inputString.reserve(200); // Reserve 200 bytes for the inputString
delay(5000);
Serial.print("\nI2C comms initiated.");
Serial.print("\nType: 'voice' or 'muted' to communicate with Nicla Voice");
void loop() {
nicla::leds.setColor(green);
delay(500);
nicla::leds.setColor(off);
if (Serial.available()) {
// Read the incoming data
inputString = Serial.readStringUntil('\n');
if (inputString == "voice") {
Wire.beginTransmission(deviceAddress);
Wire.write("voice", 5);
Serial.print("\nSent: voice");
nicla::leds.setColor(blue);
byte error = Wire.endTransmission();
if (error) {
Serial.print("\nMessage not received. ");
Serial.print("\nTransmission error: ");
Serial.println(error);
nicla::leds.setColor(red);
else {
Serial.print("\nMessage: 'voice' received. ");
delay(1000);
if (inputString == "muted") {
Wire.write("muted", 5);
Serial.print("\nSent: muted");
if (error) {
else {
Serial.print("\nMessage: 'muted' received. ");
delay(1000);
Into this one:
#include "ei_syntiant_ndp120.h"
#include "NDP.h"
#include "edge-impulse-sdk/porting/ei_classifier_porting.h"
#include "ingestion-sdk-platform/nicla_syntiant/ei_at_handlers.h"
#include "ingestion-sdk-platform/nicla_syntiant/ei_device_syntiant_nicla.h"
#include "ingestion-sdk-platform/sensors/ei_inertial.h"
#include "inference/ei_run_impulse.h"
#ifdef WITH_IMU
#include "model-parameters/model_metadata.h"
#else
#include "ingestion-sdk-platform/sensors/ei_microphone.h"
#endif
#include "rtos.h"
#include "Thread.h"
#include "EventQueue.h"
#define TEST_READ_TANK 0
extern NDPClass NDP;
static ATServer *at;
static bool ndp_is_init;
#if TEST_READ_TANK == 1
static void test_ndp_extract(void);
#endif
static void error_event(void);
static void match_event(char* label);
static void irq_event(void);
static bool _on_match_enabled = false;
static volatile bool got_match = false;
static volatile bool got_event = false;
void ei_setup(char* fw1, char* fw2, char* fw3)
uint8_t valid_synpkg = 0;
bool board_flashed = false;
uint8_t flashed_count = 0;
EiDeviceSyntiantNicla *dev = static_cast<EiDeviceSyntiantNicla*>(EiDeviceInfo::get_device());
char* ptr_fw[] = {fw1, fw2, fw3};
ndp_is_init = false;
Serial.begin(115200);
Serial.println("Starting setup...");
nicla::begin();
Serial.println("Nicla System initialized.");
nicla::disableLDO();
Serial.println("LDO Disabled.");
while (!Serial) {
Serial.println("Waiting for Serial...");
Serial.println("Hello from Edge Impulse on Arduino Nicla Voice\r\n"
"Compiled on " __DATE__ " " __TIME__);
NDP.onEvent(irq_event);
NDP.onMatch(match_event);
dev->get_ext_flash()->init_fs();
Serial.println("External Flash File System Initialized.");
for (int8_t i = 0; i < 3 ; i++) {
if (ptr_fw[i] != nullptr){
if (dev->get_file_exist(ptr_fw[i])){
Serial.printf("%s exists.\n", ptr_fw[i]);
valid_synpkg++;
else{
Serial.printf("%s not found!\n", ptr_fw[i]);
if (valid_synpkg == 3){
Serial.println("All firmware packages are valid.");
NDP.begin(fw1);
NDP.load(fw2);
NDP.load(fw3);
NDP.getInfo();
Serial.println("NDP initialized with firmware.");
ndp_is_init = true;
#ifdef WITH_IMU
Serial.println("Configuring with IMU.");
NDP.configureInferenceThreshold(EI_CLASSIFIER_NN_INPUT_FRAME_SIZE);
#else
Serial.println("Configuring with Microphone.");
NDP.turnOnMicrophone();
NDP.getAudioChunkSize();
#endif
NDP.interrupts();
Serial.println("NDP interrupts configured.");
ei_syntiant_set_match();
else{
Serial.println("NDP not properly initialized. Missing firmware packages.");
at = ei_at_init(dev);
Serial.println("AT Server initialized.");
if (ndp_is_init) {
ei_inertial_init();
Serial.println("Inertial sensor initialized.");
ei_run_nn_normal();
Serial.println("Neural network inference started.");
Serial.println("Type AT+HELP to see a list of commands.");
at->print_prompt();
void ei_main(void)
int match = -1;
char data = Serial.read();
while (data != 0xFF) {
at->handle(data);
Serial.print("Received data: ");
Serial.println(data, HEX);
if (ei_run_impulse_is_active() && data == 'b') {
Serial.println("Stopping impulse due to 'b' command.");
ei_start_stop_run_impulse(false);
if (ei_run_impulse_is_active()) {
if (got_match) {
Serial.println("Match detected.");
got_match = false;
ThisThread::sleep_for(100);
if (got_event) {
Serial.println("Event detected.");
got_event = false;
match = NDP.poll();
if (match > 0) {
Serial.printf("Match: %d\n", match);
match = -1;
#ifdef WITH_IMU
ei_run_impulse();
#endif
void ei_syntiant_clear_match(void)
void ei_syntiant_set_match(void)
_on_match_enabled = true;
while (1) {
Serial.println("Error event triggered.");
ThisThread::sleep_for(250);
nicla::leds.end();
if (_on_match_enabled) {
if (strlen(label) > 0) {
got_match = true;
Serial.printf("Match: %s\n", label);
got_event = true;
Serial.println("IRQ event triggered.");
What I managed to do already is running code when keyword is recognized, but I can’t get I2C to work.
My integration that I tried last time:
/* Include ----------------------------------------------------------------- */
//--------------------------------------------custom code ----------------------------------
#include <Wire.h>
//----------------------------------------end of custom code--------------------------------------------
#include "NDP.h"
#ifdef WITH_IMU
#else
#endif
#include "rtos.h"
#include "Thread.h"
/* device class */
#endif
/* Public functions -------------------------------------------------------- */
* @brief
nicla::begin();
Wire.begin();
nicla::disableLDO(); // needed
while (!Serial) { /* if Serial not avialable */
ei_printf("Hello from Edge Impulse on Arduino Nicla Voice\r\n"
"Compiled on %s %s\r\n",
__DATE__,
__TIME__);
//NDP.onError(error_event);
if (ptr_fw[i] != nullptr){ // nullptr check
ei_printf("%s exist\n", ptr_fw[i]);
valid_synpkg++;
else{
ei_printf("%s not found!\n", ptr_fw[i]);
//dev->get_ext_flash()->deinit_fs(); // de init as NDP re init it
NDP.begin(fw1);
NDP.load(fw2);
NDP.load(fw3);
NDP.getInfo();
ndp_is_init = true;
#ifdef WITH_IMU
#else
NDP.getAudioChunkSize(); /* otherwise it is not initialized ! */
#endif
NDP.interrupts();
else{
ei_printf("NDP not properly initialized\n");
dev->get_ext_flash()->init_fs(); // NDP probably will de init and unmount
/* init ar server */
/* start inference */
if (ndp_is_init == true) {
/* sensor init */
ei_inertial_init();
ei_run_nn_normal();
ei_printf("Type AT+HELP to see a list of commands.\r\n");
at->print_prompt();
* @brief
void ei_main(void)
int match = -1;
/* handle command comming from uart */
at->handle(data);
if (ei_run_impulse_is_active() ==true) {
if (got_match == true){
got_match = false;
//nicla::leds.setColor(blue);// // => disabled default color
if (got_event == true){
got_event = false;
match = NDP.poll();
if (match > 0) {
ei_printf("match: %d\n", match);
match = -1;
#ifdef WITH_IMU
// for now by default we stay in inference
ei_run_impulse();
#endif
* @brief disable interrupt from NDP class
//NDP.turnOffMicrophone();
//NDP.noInterrupts();
* @brief enable interrupt from NDP clas
//NDP.turnOnMicrophone();
//NDP.interrupts();
* @brief Callback when an Error is triggered
* @note it never exit!
while (1) {
nicla::leds.end();
* @brief Callback when a Match is triggered
* @param label The Match label
if (_on_match_enabled == true){
got_match = true;
ei_printf("\nMatch: %s\n", label);
ei_printf("\nTEST BEFORE IF STATEMENT\n");
if (strcmp(label, "NN0:go") == 0) {
ei_printf("\nTEST AFTER IF STATEMENT\n");
ei_printf("\nTRYING TO ESTABLISH CONNECTION NOW\n");
delay(3000);
delay(3000);
ei_printf("\nSent: voice");
if (error) {
ei_printf("\nMessage: 'voice' failed to send. ");
else {
ei_printf("\nMessage: 'voice' received. ");
if (strcmp(label, "NN0:stop") == 0) {
delay(3000);
delay(3000);
ei_printf("\nSent: muted");
if (error) {
else {
ei_printf("\nMessage: 'muted' received. ");
* @brief
if (_on_match_enabled == true) {
got_event = true;
Has this been disussed before?
Any tips otherwise?
I am attaching Nicla Vision code too just in case:
#SETUP_START
from pyb import I2C
from machine import LED
import sensor
import time
import image
import tf
import os
import gc
import uos
# Variables - FPS clock
clock = time.clock()
# Variables - I2C communication
i2c = I2C(1, I2C.SLAVE, addr=0x42)
# Variables - Led
led_blue = LED("LED_BLUE")
led_red = LED("LED_RED")
led_green = LED("LED_GREEN")
#led_blue.on()
#led_red.on()
#led_green.on()
def led_off():
led_blue.off()
led_red.off()
led_green.off()
# Variables - Emotion recognition
net = None
labels = None
# Variables - Loop switch
loop_switch = False
# Sensor settings for face detection
sensor.reset()
sensor.set_contrast(3)
sensor.set_gainceiling(16)
sensor.set_framesize(sensor.HQVGA)
sensor.set_pixformat(sensor.GRAYSCALE)
# Load function for I2C communication
def readData():
global loop_switch
buf = bytearray(5) # Adjust buffer size for the string length
try:
i2c.recv(buf, timeout=1)
message = buf.decode('utf-8') # Convert bytes to string
print('Message received:', message, '\n')
if message == 'voice':
loop_switch = True
print('loop_switch is', loop_switch)
if message == 'muted':
loop_switch = False
except:
pass
# Load Haar Cascade for face detection
face_cascade = image.HaarCascade("frontalface", stages=25)
# Load emotion recognition model
try:
net = tf.load("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
labels = [line.rstrip('\n') for line in open("labels.txt")]
except Exception as e:
print(e)
raise Exception('Failed to load model or labels.')
#SETUP_END
#Main loop
while True:
led_off()
led_green.on()
led_blue.on()
readData()
if loop_switch == True:
while loop_switch:
readData()
clock.tick()
# Capture snapshot for face detection
img = sensor.snapshot()
# Find faces
faces = img.find_features(face_cascade, threshold=0.9, scale_factor=1.25)
face_detected = False # Flag to check if any face is detected
for face in faces:
face_detected = True # Set flag to true as face is detected
img.draw_rectangle(face)
# Turn on white LED as soon as a face is detected
led_off()
led_blue.on()
led_red.on()
led_green.on()
# Crop the image to the face region
face_img = img.copy(roi=face)
# Run emotion recognition on the cropped face image
emotion_detected = False
for obj in net.classify(face_img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
predictions_list = list(zip(labels, obj.output()))
for label, confidence in predictions_list:
print("%s = %f" % (label, confidence))
if label == 'sad' and confidence > 0.4:
led_off()
led_blue.on()
time.sleep(1.2)
emotion_detected = True
break
elif label == 'happy' and confidence > 0.8:
led_off()
led_green.on()
time.sleep(1.2)
break
if emotion_detected:
break
break # Exit the loop after processing the first face
if not face_detected:
led_off()
led_red.on() # Turn on red LED if no face is detected
print(clock.fps(), "fps")
if loop_switch == 0:
led_off()
led_green.on()
led_blue.on()
readData()
