Question/Issue: I am using a Nicla Vision to classify 5 objects. I have used the 96 x 95 frame. I have taken 20 images for each object. I have chosen Auto-balance dataset and Data augmentation. 30 learning cycles, learning rate of 0.005, and 20% validation size. There is an accuracy of only 55%, however, Live classification works reasonably well. When I try to build the deployment, and also choosing the Quantized compiler, I am getting the error
/root/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: /tmp/arduino-sketch-678B6DF46E949D293299A3BDECCBC03B/firmware-arduino-nicla-vision.ino.elf section `.text' will not fit in region `FLASH'
/root/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: region `FLASH' overflowed by 316808 bytes
However, the spec of the Nicla Vision is
2MB Flash/1MB RAM
16MB QSPI Flash for storage
But the compiler states that the memory being used is 346.9K, and the flash usage is 581.0K.
Can anyone help me understand why this error is coming up?
Project ID: 195513
Context/Use case: Image classification
