Hi - I have a 2015 iMac running Big Sur. I believe I’ve installed the software needed per the directions. When I try to flash the firmware onto the dev board, the script reports back that the device cannot be found. So far I cannot see why (it is plugged into the computer via USB and seems to be reset to boot loader mode per instructions). Next steps please?
Hi @mlimkeman,
Can you verify the board is showing up in the OS?
ls /dev/cu.usb*
If it doesn’t return anything I would suspect the USB cable, some don’t support data transfer.
That did it! Thanks.
