Multi-Output Regression?
I’d like to use Edge Impulse to create a model that takes speech and outputs articulation parameters used to control Pink Trombone, an articulatory speech synthesizer. I’ve done some examples before using simpler models (I’m not that good at ML stuff), and I figured Edge Impulse would be a better solution.
I’ve used Edge Impulse before to create a classifier with our smart insoles, as well as a simple regression model using a Wii Balance board. Is it possible to create a regression model that provides multiple outputs (index and diameter of multiple vocal tract constrictions, 6 total)?
Hey @zack.qattan
Good to see you on here again hope the project is going well, unfortunately speech synthesis is not something we can discuss as its violation of our responsible AI policy, its not really something we would be supporting either as its not directly applicable to Edge Impulse firmware / features.
