Hello, I’ve recently been looking into having two separate models running on a Xiao ESP32 S3 by merging the two together. However, when looking into the documentation posted on Edge Impulse, I noticed that the file names and files themselves weren’t quite the same. For example, the documentation has files such as tflite-traned.cpp, whereas the current tflite-model file does not have this file at all.
So, my question is, how would I go about merging the two models together now? Which variables and lines of code do I need to rename and change in order to get it to work?
Please check out the python script in the custom deployment block:
If you don’t want to add the deployment block to your organization, you can also test the scripts locally. That should be more convenient than modifying all the files.
Also:
