¿Como funciona el reentrenamiento y cuando lo recomiendan usar?
¿aumenta o disminuye la precisión?
Hi @Blechon,
The “Retrain Model” is useful when adding new data to your project. It regenerates features from your DSP block and retrain the Neural Network model in one single step. You can see it as a shortcut as you don’t need to go through all the blocks in your impulse one by one.
@aurel la precision se mantiene o cambia?, porque al terminar el entrenamiento no indica algun valor de precision o el tiempo de inferencia.
todos esos valores se mantienen?
If you’re adding/removing data in your training set this will most likely change the accuracy of the model. You can check the new values on the Neural Network page.
