Model_variables.h Compile Errors
After retraining the model, use CMSIS-PACK to deploy it. After installing PACK, the model_variables.h file compilation error occurs. Compared with the previous model_variables.h file, some modifications have been made.
  • Always
  • Platform: [STM32F407]
  • Build Environment Details: [MDK KEIL5.36]
  • OS Version: [Windows 10]
  • Edge Impulse Version (Firmware): [1.72.17]
  • Project Version: [7.0.0]
***/edgeimpulse\model-parameters/model_variables.h(104):
.output_tensors_indices = ei_output_tensors_indices_9,
***/edgeimpulse\model-parameters/model_variables.h(105):
.output_tensors_size = ei_output_tensors_size_9,
***/edgeimpulse\model-parameters/model_variables.h(129):
&run_nn_inference,
&run_nn_inference,
static_cast( )
**/edgeimpulse\model-parameters/model_variables.h(130):
(void
)&ei_learning_block_config_9,
***/edgeimpulse\model-parameters/model_variables.h(132):
ei_learning_block_9_inputs,
***/edgeimpulse\model-parameters/model_variables.h(133):
ei_learning_block_9_inputs_size,
***/edgeimpulse\model-parameters/model_variables.h(137):
&run_kmeans_anomaly,
static_cast( )
**/edgeimpulse\model-parameters/model_variables.h(138):
(void
)&ei_learning_block_config_19,
***/edgeimpulse\model-parameters/model_variables.h(140):
ei_learning_block_19_inputs,
***/edgeimpulse\model-parameters/model_variables.h(141):
ei_learning_block_19_inputs_size,
***/edgeimpulse\model-parameters/model_variables.h(145):
const ei_fill_result_classification_i8_config_t ei_fill_result_classification_i8_config_9 = {
***/edgeimpulse\model-parameters/model_variables.h(154):
.type = EI_CLASSIFIER_MODE_CLASSIFICATION,
***/edgeimpulse\model-parameters/model_variables.h(157):
.postprocess_fn = &process_classification_i8,
13 errors generated.
I just reinstalled the new PACK file, and the main program was not modified. Since this model_variables.h file is locked (read-only), the problem should be in the generated library file. Please tell me how to solve it, thank you!
@dannydeng,
When you reinstalled the new PACK did you reinstall also the EdgeImpulse.EI-SDK.x.y.z.pack?
The errors suggest that the model_variables.h and the EI-SDK are out of sync. They should always be updated together.
// Raul
@dannydeng,
I’ve found the issue. The EI-SDK.x.y.z pack in the export is outdated. We are working on a fix.
In the meantime can you grab the latest EI-SDK.x.y.z.pack which is (currently) version 1.72.14 from Arm Keil | EdgeImpulse EI-SDK and let me know whether this unblocks you.
// Raul
Hi @rjames ,
This version(EI-SDK.1.72.14 ) is usable and the compilation errors are fixed.
Thanks for your efforts!
@dannydeng,
The issue has been resolved in Studio.
Thanks for reporting.
// Raul
