Question/Issue: When creating more than one learning block the model testing section runs but does not display the results.
Project ID: 238284
Context/Use case: Testing our models is not possible
Project ID: 238284
Hi @OTH-MAN
Welcome to the forum!
You need look into the confidence thresholds, on each of the learn blocks for your project. If you set the confidence threshold to very low like 0.0000001 and you still don’t see any table then there is a problem with one of your learn blocks configuration.
Try testing each of the learn blocks independently by deleting the others to find the problematic one.
