When using MFE on a dataset, and trying to generate features i get following error, thats looks like an “off by one” indexing issue.
I cannot find the rerenced file “/home/…/third_party/speechpy/processing.py” to dive into implementation, have looked in the “processing-blocks” repos on github.
Any clues ?
Creating job… OK (ID: 538065)
Job started
Creating windows from 32 files...
[ 0/32] Creating windows from files...
[ 1/32] Creating windows from files...
[32/32] Creating windows from files...
Created 96 windows: inner: 45, outer: 51
Scheduling job in cluster...
Job started
File "/home/create_features.py", line 71, in <module>
Creating features
axes, freq, frame_length=0.02, frame_stride=0.01, num_filters=32, fft_length=256, low_frequency=300, high_frequency=None, win_size=101)
File "/home/dsp.py", line 51, in generate_features
low_frequency=low_frequency, high_frequency=high_frequency)
File "/home/../third_party/speechpy/feature.py", line 196, in mfe
zero_padding=False)
File "/home/../third_party/speechpy/processing.py", line 141, in stack_frames
frames = signal[indices]
IndexError: index 12500 is out of bounds for axis 0 with size 12500
Job failed (see above)
