How do I retrieve Profile information using the Profiling APIs.
It says to use getProfileTfliteJob and I’m not sure where and how to call this function/api.
Any help on this would be highly appreciated.
Pratyush
Pratyush
Hi Pratyush,
The API can be used if you are building a local python script for instance, and you need to retrieve the information from the studio using the script.
You can use Python or cURL to retrieve this information.
Omar
Hi @pratyush
try this:
import requests, json, datetime, time, re, base64
PROJECT_ID = 1 # YOUR PROJECT ID
API_KEY = "ei_..." # YOUR API KEY
DEVICE = 'infineon-cy8ckit-062s2'
REFERENCE_MODEL = 'keywords-2d-i8' # just hardcode this for now
def profile_tflite_model(tflite_file_path):
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/jobs/profile-tflite"
base64_encoded_file = ''
with open(tflite_file_path, "rb") as f:
base64_encoded_file = base64.b64encode(f.read()).decode('utf-8')
payload = {
'tfliteFileBase64': base64_encoded_file,
'device': DEVICE,
'referenceModel': REFERENCE_MODEL,
headers = {
"x-api-key": API_KEY,
"Accept": "application/json",
"Content-Type": "application/json",
response = requests.request("POST", url, json=payload, headers=headers)
body = json.loads(response.text)
if (not body['success']):
raise Exception(body['error'])
return body['id']
def get_stdout(job_id, skip_line_no):
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/jobs/{job_id}/stdout"
headers = {
response = requests.request("GET", url, headers=headers)
stdout = body['stdout'][::-1] # reverse array so it's old -> new
return [ x['data'] for x in stdout[skip_line_no:] ]
def wait_for_job_completion(job_id):
skip_line_no = 0
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/jobs/{job_id}/status"
headers = {
while True:
stdout = get_stdout(job_id, skip_line_no)
for l in stdout:
print(l, end='')
skip_line_no = skip_line_no + len(stdout)
if (not 'finished' in body['job']):
# print('Job', job_id, 'is not finished yet...', body['job'])
time.sleep(1)
continue
if (not body['job']['finishedSuccessful']):
raise Exception('Job failed')
else:
break
def get_perf_results(job_id):
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/jobs/profile-tflite/{job_id}/result"
headers = {
response = requests.request("POST", url, headers=headers)
return body
if __name__ == "__main__":
job_id = profile_tflite_model('path-to-your-tflite-file.tflite')
print('Job ID is', job_id)
print('Job', job_id, 'is finished')
perf_data = get_perf_results(job_id)
print('Memory usage', perf_data['memory'])
print('Time per inference (' + DEVICE + ')', perf_data['timePerInferenceMs'])
