Hello. I have built the firmware for my board and am trying to run the impulse. However, in Powershell, the script just stops at “LSE” line. Before that it says “Starting inferencing”. Any tips?
Thank you
Hi @E33933, mind posting a screenshot/the full output here? Which board did you build the firmware for?
Hi @E33933
Can you please try reflashing to your board and can you try using a different usb cable to connect your board to your computer?
@E33933 which firmware is this running? The one from https://docs.edgeimpulse.com/docs/eta-compute-ecm3532-ai-vision#2-update-the-firmware or a custom one?
Note that the AI Vision board has been discontinued by Eta Compute.
