thanks for the reply Shawn. before I decided to compare the classification value I initially used that method of setting a threshold say 1.5(considering anomaly can be any value). but it also didn’t work so I decided to compare it. anyway I will go back to your suggestion of comparing it
here is the code
#include <stdio.h>
#include "pico/stdlib.h"
#include "ei_run_classifier.h"
#include "pico/binary_info.h"
#include "hardware/gpio.h"
#include "hardware/i2c.h"
const uint LED_PIN=25;
const uint MODE_ONE=18;
const uint MODE_TWO=19;
const uint ANOMALY_STATE=20;
const float debug_nn = false;
// By default these devices  are on bus address 0x68
static int addr = 0x68;
#ifdef i2c_default
static void mpu6050_reset() {
    uint8_t buf[] = {0x6B, 0x00};
    i2c_write_blocking(i2c_default, addr, buf, 2, false);
static void mpu6050_read_raw(int16_t accel[3]) {
    uint8_t buffer[6];
    // Start reading acceleration registers from register 0x3B for 6 bytes
    uint8_t val = 0x3B;
    i2c_write_blocking(i2c_default, addr, &val, 1, true); // true to keep master control of bus
    i2c_read_blocking(i2c_default, addr, buffer, 6, false);
    for (int i = 0; i < 3; i++) {
        accel[i] = (buffer[i * 2] << 8 | buffer[(i * 2) + 1]);
#endif
int main()
    stdio_init_all();
    gpio_init(LED_PIN);
    gpio_set_dir(LED_PIN, GPIO_OUT);
    gpio_put(LED_PIN, 0);
    gpio_init(MODE_ONE);
    gpio_set_dir(MODE_ONE, GPIO_OUT);
    gpio_put(MODE_ONE, 0);
    gpio_init(MODE_TWO);
    gpio_set_dir(MODE_TWO, GPIO_OUT);
    gpio_put(MODE_TWO, 0);
    gpio_init(ANOMALY_STATE);
    gpio_set_dir(ANOMALY_STATE, GPIO_OUT);
    gpio_put(ANOMALY_STATE, 0);
    i2c_init(i2c_default, 400 * 1000);
    gpio_set_function(PICO_DEFAULT_I2C_SDA_PIN, GPIO_FUNC_I2C);
    gpio_set_function(PICO_DEFAULT_I2C_SCL_PIN, GPIO_FUNC_I2C);
    gpio_pull_up(PICO_DEFAULT_I2C_SDA_PIN);
    gpio_pull_up(PICO_DEFAULT_I2C_SCL_PIN);
    // Make the I2C pins available to picotool
    bi_decl(bi_2pins_with_func(PICO_DEFAULT_I2C_SDA_PIN, PICO_DEFAULT_I2C_SCL_PIN, GPIO_FUNC_I2C));
    mpu6050_reset();
    int16_t acceleration[3];
        return 1;
    while (true){
        ei_printf("\nStarting inferencing in 2 seconds...\n");
        sleep_ms(2000);
        gpio_put(LED_PIN, 1);
        ei_printf("Sampling...\n");
            uint64_t next_tick = ei_read_timer_us() + (EI_CLASSIFIER_INTERVAL_MS * 1000);
            mpu6050_read_raw(acceleration);
            buffer[ix] = acceleration[0];
            buffer[ix + 1] = acceleration[1];
            buffer[ix + 2] = acceleration[2];
            sleep_us(next_tick - ei_read_timer_us());
        signal_t signal;
        if (err != 0) {
            return 1;
        // Run the classifier
        if (err != EI_IMPULSE_OK) {
            return 1;
        // print the predictions
        ei_printf("Predictions ");
        ei_printf(": \n");
            ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
    #endif
    if ((result.classification[0].value >= result.classification[1].value)&&(result.classification[0].value >=result.anomaly)) {
          gpio_put(MODE_ONE, 1);
    else if  ((result.classification[1].value >= result.classification[0].value)&&(result.classification[1].value >=result.anomaly)) {
          gpio_put(MODE_TWO, 1);
    else
          gpio_put(ANOMALY_STATE, 1);
#endif
return 0;
